      11-21-2021, 12:24 PM   #1
Minton444
Drives: 2006 525xi e60
Car is acting like it is low and then dead but the battery is good
Went to start my 06 e60 525xi this morning. It's acting like the battery was almost dead. After two tries it stopped turning over as if the battery was dead. I took my battery to the local advance auto store for a test and they said it was a good battery with 811 cold cranking amps out of 900 with something like 12.7 volts. Does anyone know what could cause this issue and how to fix it?
      11-21-2021, 02:50 PM   #2
e91Owner
e91Owner
Drives: 2011 e91 & 2010 e60
Sounds like your starter is getting bad, but it could also be the grounds. There are no other symptoms other than slow starts.
To test for the ground, attach a jumper cable from the block to the ground lug in the engine bay. If it cranks right up with it, but slowly without it, you'll need a new ground strap.
If it's still slow with the ground jump, then it's starter replacement time.
