10-02-2018, 07:13 PM | #1 |
Rep 5
Rebooting CCC and loss of MOST network - 2005 525d e61
Guys, i need some help:\ E61 pre-face - The CCC unit is rebooting like a drunk idiot and when running ISTA-D i get up no communication with no of the MOST modules. But the optical light comes through all the modules, so there cant be a break in the cable. Can the CCC unit be broken so that it cant run a communication with all other units even if they are all OK and the MOST signal is working? Do the 4 condensators on the ccc-pcb make this kind of problems if they die? Or is it the whole unit thats gone? This happened suddenly, and its suuuuper annoying..
02-17-2019, 09:03 AM | #2 |
Rep 5
There is a module located in the trunk that (apparently distributes power to multiple system components. While my radio and CD are functioning, the audio cuts out every couple of minutes for about 5sec. I bypass looped the MULF module but still had same result. A friend recommended I check the power module located under the spare tire. Which I will try today. If this is the cause for my car's issues it may be worth checking in your car
03-01-2019, 09:08 PM | #3 | |
Work Hard! Play Harder!!
47
Rep 193
Drives: BMW 1M, BMW M3 CS
