      09-14-2020, 01:16 PM   #1
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
This 3 stage manifold is ready to install. Fully refreshed, cleaned and tested. Waiting to find an N52 as it's new home
I take apart the disa valve flaps and clean them, test the internals, grease them and put them back together and test how they work thoroughly to make sure they're in good working shape, most valves straight out of a used car will be faulty or slow so this is a huge plus to this manifold. Also these disas are both updated revision valves with no risk at all of anything dropping into the intake.
On a fully stock 525i N52 with the proper software (which I sell aswell) you can expect +45hp gain and +35lb ft of torque, even more gains in the midrange.
On a fully stock 528i N52 you can expect +30hp and +20lb ft of torque with even more gains in the mid range aswell.
Videos of valves working:
Large disa
Small disa
$320
I don't include shipping but depending where you live we can work something out
http://rover.ebay.com/rover/1/711-53...8;toolid=11111
      11-30-2020, 06:48 PM   #2
matress
Drives: 2008 BMW 528i
Has anyone on this forum every actually successfully done a 3-stage manifold swap for a 528i?
      11-30-2020, 10:49 PM   #3
E92William
I'm sure it has been done. I don't see a reason why it would fit on a 128i and 328i n52 and it wouldn't on a 528 with the exact same engine. As a matter of fact the F10 528s with the n52 come with the 3 stage manifold from factory
      12-01-2020, 10:51 PM   #4
mweine
Work Hard! Play Harder!!
mweine's Avatar
Drives: BMW 1M, BMW M3 CS
1989 BMW M3  [0.00]
Large disa
Small disa
$320
Would it increase the Hp and torque in an 2008 X3 3.0si with the highest tuned stock N52 at 276Hp?
      12-01-2020, 11:01 PM   #5
E92William
Large disa
Small disa
$320
You could get there with supporting mods but in reality a manifold swap by itself won't get the car to that power level because well, no stock n52 ever came out with that power output. A lot of horsepower figures are mixed up with the euro n53 which puts out 272hp. With the bimmerlabs 330i tune you'd easily be at 258 which is right there with the 3.0si which is rated at 260, but the amount of power you make doesn't depend on the 3 stage by itself but rather what tune you run on the car.
