THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum Regional Forums AUSTRALIA EB M235i
      04-04-2014, 05:16 AM   #1
Active
Australia
32
Drives: BMWM235i and 2013 E92 M3
EB M235i
Project EB M235i is underway with the team from CITY PERFORMANCE CENTRE!
      04-07-2014, 03:50 PM   #2
BenWM
BenWM's Avatar
Australia
10
Drives: 2014 F22 M235i
Absolute beauty! And congrats on being the first post in the Aussie forums!
I didn't like those wheels at first, but they are really growing on me, and I even don't mind the runflats.
Have you ever felt that the front splitter may be a little low though? Specifically for speed bumps and driveway crossovers anyway.
      04-07-2014, 03:54 PM   #3
Active
Australia
32
Thanks! Changed the run flats to a high performance tyre. The run flats are crap!
      04-07-2014, 03:56 PM   #4
Active
Australia
32
The front of the car gives the impression that it is a little low. However to this point no altercation with speed bumps! The non run flats lifts the car by an inch or two.
      04-07-2014, 03:57 PM   #5
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
+1
      04-07-2014, 06:51 PM   #6
One///Em
Drives: 1M
"MPOWER" plates...seriously? Aren't there like already 16 ///M badges on this non-M car?
Looking great otherwise, but not loving the wheels.
      04-07-2014, 07:43 PM   #7
TWD
Australia
45
Drives: All sorts of Cars
Nice! Another "ACTIVE" transformation
Keen to see this thing when you're finished with it mate.
      04-07-2014, 07:51 PM   #8
Active
Australia
32
Unfortunately not a lot of options with 19 rims to fit this car. Waiting to see what comes to market sooner than later
      04-07-2014, 08:55 PM   #9
paka
Australia
Drives: M235
What tyres did you change to? Have runflats on mine and thinking about swapping them out.
      04-08-2014, 07:05 AM   #10
Active
Australia
32
Always a pleasure catching up with you mate! Hopefully the tune will be completed on Friday. Suspension setup and exhaust when available..........
      04-08-2014, 07:57 AM   #11
Active
Australia
32
Michelin Super Sport 225/40/19
Michelin Super Sport 255/35/19
      06-05-2014, 07:09 PM   #12
dtcoff
Australia
49
M235i doesn't have runflats, only the lower models. They come standard with Michelin PSS.
2014 M235i / EB-II / Coral / Sunroof / Comfort & Parking Packages
2014 X3 3.0d / M sport / AW / Sunroof
      06-05-2014, 07:43 PM   #13
Active
Australia
32
They do come with runflats if you opt for the 19inch M Performance rims, unfortunately!
      07-11-2014, 07:42 AM   #14
Active
Australia
32
KW V3s and AFE air intake fitted
KW V3s and AFE Air Intake fitted today.
      07-15-2014, 06:37 PM   #15
andrew@southernBM
andrew@southernBM's Avatar
169
Drives: M2 G87, M4 G82
Looks the goods, how are you enjoying the car, how does it feel with the different suspension compared to stock. I'm interested in the feedback.
Do you have adaptive suspension in your car? If so, did you consider the new DDC's that plug n play's into your factory adaptive?
The adaptive KW DDC plug&play coilover kit is an intelligent retrofit solution for the BMW 2-series Coupé which is fitted with adaptive M suspension. In addition to adjustable lowering, the electronically adjustable KW suspension allows for a sportier damping setup or a more comfortable ride at the push of a button. "When choosing the sport mode, the BMW 2-series feels much more direct and agile with the DDC coilovers ", explains KW Product Manager Johannes Wacker. „If that's too sporty for the road condition, simply press the original BMW button and within five milliseconds, the KW damper will switch ride mode to comfort." This is possible with the adaptive KW DDC technology and electromechanical valves. The KW DDC is compatible with the original BMW driving electronics which means that no modification of the OE electronics is necessary. "The complete suspension control works via the original sensors which in turn control the KW valves. To install the suspension kit, simply replace the standard suspension with the KW suspension and the KW DDC connectors can be connected to the original plugs", the KW suspension works in harmony with the original BMW control and "It works so quick and harmonically, that you can hardly notice it in everyday use” said Johannes Wacker.
The ride height adjustment of the adaptive KW DDC plug&play coilovers comes via the dirt-resistant KW trapezoid thread on the stainless steel strut and the rear axle height adjustment collars. The German TÜV tested adjustment range on the 2-series allows a continuously adjustable lowering of 25 to 50 millimeters on both axles. The adaptive KW coilover kit is also available for the BMW M235i, with a TÜV-tested adjustment at the front axle of 10 to 35 millimeters and 5 to 35 millimeters on the drive axle.
      07-20-2014, 04:37 AM   #16
Active
Australia
32
Enjoying the M235i! The KW V3s give the car better handling without any harsh feel as experienced from time to time in my E92 M3. The M235 is always driven in sport mode hence the V3 coilovers. The car did have the adaptive suspension when I purchased it. Just ordered the MPerformance exhaust with the carbon tips. That should finish this car off.
      07-20-2014, 07:02 AM   #17
235newbie
Drives: M235i
what is the lip on this?
      07-20-2014, 07:03 AM   #18
Active
Australia
32
MPerformance part
      08-24-2014, 06:23 AM   #19
Active
Australia
32
MPerformance Exhaust
The MPerformance exhaust is impressive from an aesthetic perspective and sounds a heap better than the standard.
      08-24-2014, 06:28 AM   #20
MO3
MO3's Avatar
Australia
163
Drives: DCT M3
I like the carbon tips. Would love to hear it in person.
      08-24-2014, 06:38 AM   #21
Active
Australia
32
No problem, happy to catch up some time, where about in Sydney are you?
      08-24-2014, 07:29 AM   #22
MO3
MO3's Avatar
Australia
163
Drives: DCT M3
Thanks mate! I'm in Auburn, Western Sydney!
Current: 2018 M3 | individual Fire Orange
Gone: 2016 M4 | BSM
2addicts
