05-06-2019, 05:27 PM | #23 |
Rep 10
I did my first wash on my CB 40i today with a foam cannon and some chemical brothers snow foam.
I've always wanted an excuse to get a spotless rinse system like the CR Spotless so went to a couple local window wash supply houses to see what they have. I picked up an Unger HydroPower setup instead as it's much less obtrusive than the CR Spotless one. The concept behind these systems with the filter media is all the similar. The Unger has also recently released a consumer version of this that's smaller and cheaper they call the Rinse-n-Go https://ungerconsumer.com/product/rinse-n-go/ The good thing about this system is I got the combo kit with telescoping brush to use it for its main intended purpose of cleaning all my house windows. I've had a service come in previously and the guys used a similar system and windows all come spotless. Easy and quick. |
06-29-2019, 08:49 PM | #24 | |
Rep 240
1 - rinse with 25 degree power wash 2 - foam coverage - he uses Feynlab Pure Wash 3 - hand wash with microfiber, Feynlab Rinseless 4 - Rinse 5 - Dry with microfiber My question is whether you do the foam/rinse or the method above. Thanks! |
02-13-2020, 07:48 PM | #25 | |
Rep 198
https://puretecwater.com/ These are industrial quality tanks but they can deliver to your home. One tank gets you 700-1000gallons. See my post here : Here's a good alternative to CRSpotless. It provides industrial quality DI water My post here: https://g05.bimmerpost.com/forums/sh...6&postcount=33 Last edited by araje; 02-13-2020 at 08:02 PM.. |
03-06-2020, 04:42 PM | #26 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
I washed the car earlier, it was *filthy* so my concern was to detach as much grit as possible first.
+ Power wash with plain water, everywhere, wheel arches etc etc to remove the mud and worst bits + Snow foam to get some lubricant everywhere. + One bucket with water with shampoo, and a soft brush, brush the car everwhere gently, keeping the brush soaked in shampoo to remove stuff that is attached to the paint. + Rince with the hose (already look a lot better) + Two bucket wash with a mitt -- here it's nice because I know the paint has /most/ of the grit removed + Rince again with the hose (not the power washer), loads of water to remove anything that's been detached from the paint. Then: + Electric leaf blower to 90% dry the car (look these up, they are AWESOME, especially you guys who have water marks!) + Two large microfiber towels (from Decathlon) + ONE where I spray the "Meguiar's G190526EU Hybrid Ceramic Wax" and put a gentle coat on one/two panels at a time + ONE that is dry and I use for buffing a bit. That's it. I didn't do a full wheel clean as it's winter and the car will be dirty tomorrow again; what I wanted was remove the salt and grit from the road and revive the ceramic hybrid coating.
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
03-09-2020, 09:31 AM | #27 | |
Rep 418
Drives: ‘20 X5/M50i (ordered); &
03-09-2020, 06:06 PM | #28 | |
Owner
132
Rep 566
Microfiber is great, but it won't prevent you sanding down the paint with what you collect. unless you have 600 microfiber cloth pads, one for each stroke. IMO, a good brush, with a soak of shampoo as lubricant will detach a LOT of the "worst" on the paint before you go 'closer'. thats why I use my method of like 3 'passes': 1) remove the real shit of the car with pressure washer+foam canon, 2) remove all you can of the worst bits attached to the paint with the brush and 3) go with the soaked mits to detach the rest.
03-09-2020, 06:28 PM | #29 | ||
Rep 418
03-31-2020, 04:08 PM | #32 | |
Rep 202
Drives: BMW X5
Konpard Ultimate Car Wash Mitt - 2 Pack - Premium Chenille Microfiber Wash Mitt - Wash Sponge - Wash Glove - Lint Free - Scratch Free https://www.amazon.com/dp/B07WT7DPXV..._Jd7GEbJ42220D |
04-19-2020, 07:29 AM | #33 |
Rep 52
This might help you...
Focus on the wheels. Use a hose with a nozzle that provides good water pressure to spray the wheels of the car. ...Prep and lather. Spray the entire vehicle with water to rinse away surface dirt and to give your vehicle a good coating of water. ...Rinse and dry. |
04-19-2020, 08:24 AM | #34 |
Rep 103
I have ran the gambit over the years - now use Chemical Guys for everything. Their product consistency/potency is always consistent and great quality.
I am getting ceramic this week so going to use their ceramic wash and spray detailer. Up until that point I have been using V07 wash and the two bucket method in addition to a pre wash foam cannon run. Sonax for the wheels |
04-20-2020, 01:35 AM | #35 | |
Rep 22
advrider651070.50 |
