Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Watches
      06-17-2016, 09:20 PM   #1
zuckuss07
Drives: F30 328i M 6-Speed
Replacing watch bracelets yourself...?
Hey guys,
I recently just starting to get into timepieces. I picked up a decent entry level Tudor piece with a stainless bracelet which is nice, however, I like to swap between that and a NATO strap during the warmer time of the year.
As I've come to learn, most newer style watches use spring pins to attach the band to the case. What tools do you guys use to swap out bands? Or do you have an AD do it for you every time you wish to swap out bands or bracelets?
Seems a little cumbersome to have a dealer do it everytime.
      06-17-2016, 09:33 PM   #2
overcoil
Drives: M235i 6spd
This might be useful
http://www.tztoolshop.com/FB_Catalog..._Removers.html
      06-18-2016, 07:36 AM   #3
jtodd_fl
2nd Asst to Dept Undersecretary
jtodd_fl's Avatar
6704
Drives: People crazy
2015 F82 M4  [9.00]
2016 F87 M2  [0.00]
2011 E92 M3  [0.00]
I went with a Minathor "Swiss army" knife. A little pricey, but has lots of good tools.
http://www.ebay.com/itm/WENGER-BERGE...-/160659860657
This space for rent.
      06-18-2016, 09:47 AM   #4
Sephiroth
4-6-8
Sephiroth's Avatar
India
234
Drives: for the fun of it
http://www.ofrei.com/page235.html
Likely every tool you would ever need is available there
M3 E46 PY/Black
S2000 AP2 GPW/Tan
      06-19-2016, 07:23 PM   #5
porshah
porshah's Avatar
197
Drives: M4, R8, Huracan - All topdown
Bergeon Spring Bar 6767-F has been my most valuable tool for this task. Good steady hand and lighting will go a long way.
      06-19-2016, 11:49 PM   #6
Aatish
Lofty
Aatish's Avatar
3458
Drives: i4 M50, 991.2 C2, RRS Diesel
I got a little screw driver kit from Joanne Fabrics. Does the job well.
      06-20-2016, 09:36 AM   #7
csu87
Drives: 09 335xi
I use either a small flathead screwdriver or a thin knife. I change out my straps every few months to keep it interesting.
      06-20-2016, 01:47 PM   #8
TortugaX5
Drives: 2016 F15 X5 X35i
Depending on the model of Tudor you've purchased you may need to get two tools. If your SS bracelet has removable lugs, you'll want to get yourself a pair of needle nose tweezers to help you toggle both pins at once to secure the lug to the case and bracelet to the lug.
I own a 79260 Tudor Prince Date - a real treat to own and I swap between leather, stainless, and perlon bracelets.
https://www.amazon.com/Bergeon-6767-...pring+bar+tool
https://www.amazon.com/Needle-Stainl...zers+for+watch
PS. Don't let a dealer do any of this work, they are essentially taking money from you. When doing cosmetic work the main requirements are patience and a steady hand. Bring it in when it stops working...
      06-20-2016, 02:24 PM   #9
Irishsig
In Hoc
Irishsig's Avatar
Drives: 2016 M4 6MT MG/SO
2016 BMW M4  [0.00]
You'll also want to get a screw case back opener for battery replacement.
They usually charge $20 for 5 min of work of swapping out battery.
http://www.ebay.com/sch/sis.html?_nk...72.m2749.l2658
2016 M4 MG/SO 6MT- Max PSI Intakes - BMS Stage 1 - Swift Spec R - CG Precision Valve controller - 20" DPE Flowtech 5S - AA Midpipe & all the external CF goodies.
      06-21-2016, 07:22 AM   #10
csu87
Drives: 09 335xi
Does Tudor even have a quartz movement?
OP, for a case back opener, get one of the rubber ball openers. I havent come across a case back that I couldnt open with it, and it is easy to use and doesnt scratch up the back. Ive taken off 40 year old watch backs on Divers that im pretty sure were never removed during the life of the watch with them.
https://www.amazon.com/Friction-Ball.../dp/B0058EDAUA
      06-22-2016, 08:01 AM   #11
finaloption
finaloption's Avatar
Drives: '13 f30 n26
+1 for Bergeon tool
i prefer the 6111 over the 6767-F
quality product
