08-23-2024, 04:00 AM | #1 |
Rep 2
NBT Retrofit in E63 with Logic7
Hoping someone can help here.....
I have an E63 with a Logic7 and a failed CCC unit so, I purchased the BimmerrRetrofit box with an NBT head unit (might not have been my best decision). The install has generally gone ok and the NBT powers up, and works as expected with one exception, no sound. I've updated the original, 2004 to 2012 Logic7 because many have said very early units were problematic, no change. I've checked the MOST loop and used bypass loops on the TCU/MULF and the SAT TV unit. I can see red light returning to the NBT on the optical loop so it would appear the MOST loop is intact. Only the NBT, Logic7 and the CD unit in the glove box remain in the optical loop. I powered the NBT unit with an emulator on the desktop and used a network connection to look at its contents with E-sys. It was already set for TopHiFi (Logic7) and the maps and navigation work correctly for my region with no programming by myself so I assume BimmerRetrofit configured the NBT prior to delivery. However, with the unit in the car and connected up, no sound. Interestingly, adjusting the volume on the connected faceplate does not show any response on the NBT interface. I can programme and select pre-programmed stations from the faceplate so assume there is electrical connectivity and communication to the faceplate. Similarly the steering wheel volume control is unresponsive. However, since these are digital volume controls, it presumably involves communication with the Logic7 before showing a level and, if it cannot or will not communicate with the Logic7, it would not show any interaction. Similarly I can't specify any of the surround sound options on the NBT display since they also involve communication with the Logic7. I haven't done any programming on the car, so all of its coding remains as it was for the CCC unit. If anyone has an explanation or guide as to what is causing the problem with no sound (and how to fix it) I'd be hugely grateful. Happy to pay someone if online help is needed. This is the option list for the car, S205A Automatic transmission S217A Active steering S229A Dynamic Drive S237A DYNAMIC DRIVE PACKAGE S255A Sports leather steering wheel S302A Alarm system S346A Chrome Line exterieur S356A Climate comfort laminated glass S403A Glass roof, electrical S414A Parcel net, passenger side S428A Warning triangle and first aid kit S430A Interior/outside mirror with auto dip S431A Interior mirror with automatic-dip S436A Fine wood trim S441A Smoker package S442A Drink holder S459A Seat adjustment, electric, with memory S481A Sports seat S494A Seat heating driver/passenger S502A Headlight cleaning system S508A Park Distance Control (PDC) S522A Xenon Light S524A Adaptive Headlights S534A Automatic air conditioning S540A Cruise control S548A Kilometre speedo S563A Light package S594A BMW light alloy wheel,spider spoke 92 S601A TV function S609A Navigation system Professional S620A Voice control S638A Car telephone Professional S672A CD changer for 6 CDs S677A HiFi system Professional DSP S700A Area-Code 4 for DVD S785A White direction indicator lights S818A Battery master switch S823A Hot-climate version S825A Radio control Oceania S845A Acoustic fasten seat belt reminder S853A Language version, English S864A Dealer List Overseas S876A Radio frequency 315 MHz S880A On-board literature, English S8SAA Navigation access request,country-spec. S925A Dummy-SALAPA |
