      01-18-2021, 08:04 PM   #1
Dhillon5.bmw
Drives: Bmw 525xi 2007
Bmw 525xi e60
Has anyone had the issue where the steering wheel shakes and the whole car in the driver side front at low and high speeds car shakes at low speeds and both happens at high speed
Amarvir Singh Dhillon
      01-18-2021, 08:06 PM   #2
Dhillon5.bmw
I already had the wheels balanced and bought and mounted new tires
      01-18-2021, 10:54 PM   #3
JayArras
Casual Fanatic
32
Drives: '07 530xi
A few reasons I can think of:
1. Cracked rim
2. Bent rim
3. Wrong hub size on rim
Try swapping the front and rear tires and see if the problem shifts to the rear (unless you're staggered).
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
      01-19-2021, 02:38 PM   #4
spooner1sm
Bimmer Baby
Drives: 2008 BMW 528xi
Sort of have a similar issue in my 528xi. Noticeable vibrations that increase in frequency as the car speeds up. I'm getting new wheels and tyres soon, though, which I imagine will fix a lot of it. Some other things to check, though:
- Control arms
- Suspension bushings
- Axle
- Brake caliper
If your control arm(s) are bad, you're going to have a lot of problems. If your suspension bushings are bad, you'll get vibrations and you'll hear some pretty loud clunks and feel some instability when you go over bumps. If your axle is bent, you'll find the car feels sort of wobbly at low speeds, with a consistent vibration at higher speeds. If you've got a stuck brake caliper or brake drag anywhere, your braking is going to feel uneven and perhaps even "sticky". You'll also get vibrations and uneven brake wear.
Definitely the first place to check is going to be your wheels to make sure they're not damaged, bent, or sized wrong. I'd probably check the brake caliper(s) in the process. Then I'd go to control arm, then bushings, then axle. There's a number of other issues that cause cause that feeling, including your power steering/steering rack, your transmission, and your differentials, but it's usually something in the wheel and/or suspension, so I would look there. Good luck!
      08-26-2021, 09:48 AM   #5
Maxmil982
Drives: 2010 e60 535i xDrive
Had the same issue ended up being a bent rim
