06-10-2011, 04:09 PM | #1 |
Rep 36
Need Help Please.. How Do I Reset Idrive
i was playing music from my iphone through one of those cigarette lighter transmitters through the radio and all of a sudden it started making that interference noise and then my screen went black. then the bmw sign popped back up as if it was trying to reset it self but it wont reset. please let me know asap if anyone knows whats wrong!!!!
06-14-2011, 09:02 PM | #2 | |
Rep 14
A sure fire way to reset the iDrive is to disconnect the negative lead on the battery for at least 5 minutes and then re-connect. In actuality once you shut the car down and arm it, it will go into sleep mode within a few minutes and the iDrive should reset itself. In any event disconnecting the battery will also do the trick.
3-Stage Intake Manifold mod & Active Autowerke ECU re-map for 40+ HP Gain and 35ft-Lbs torque!, RPI GT Axle-back Exhaust System, Sprint Booster V2, RPI Scoop & BMC Filter, Carbon filter delete.
06-20-2011, 07:05 PM | #3 | |
Rep 36
thanks i did that but nothing worked. i had to get the car checked out by a dealer and i just really hope i dont have to replace any modules. it seems like its going to be really really expensive |
