F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Absolutely no audio in car!
ARMA SPEED
      11-12-2023, 11:04 AM   #1
Spanielgita
Drives: BMW 335D F31 2015
OK bit of a story here but a quick synopsis of my issue is;
Installed a Vibe amplifier to my F30 335D under seat subwoofers and forgot to unplug one from the original speaker wiring loom. I know have absolutely NO audio output through any speaker. No DAB, no BT audio, no USB audio, no door chimes, PDC etc.....
Now for some details;
The car is a base stereo unit – amplification comes from the HU which is a NBT EVO ID4
4 door card speakers and 2 under seat subs.
I originally installed the VIBE 65.4 Amplifier (harness for original ISO loom) to boost the door speakers which worked fine and was a decent upgrade. Added two Audio Fischer Co-Axial speakers to the front doors to bring some much needed treble, again system was working fine.
Now things started going wrong....
I then thought the lower end BASS felt a bit lacking so decided to get the Vibe 400.1 sub amp for the under seats. I soldered 2 new speaker cables to each sub and hooked them up to the 400.1 amp.
What I failed to do was unplug the original wiring loom from both subs. I these come from the HU to the subs and then up to the door card speakers. I unplugged the loom from the drivers side sub but not the passenger side sub.
I then foolishly powered on the amp and I now have absolutely no audio whatsoever!! There was no pops or bangs when the audio went.
Things I have checked so far;
Firstly I returned the car to stock, removing both amps and plugging in original connections as before I started anything.,
Every fuse in the boot and engine fuse box. Checked visually and with a multimeter. I actually found a blown 20A but this was related to the front cigarette socket.
Every door speaker with a multimeter and they give around 8 ohms
replaced the HU and no difference
unplugged the car battery and left overnight (12 hours).
Only things left I can think that might be damaged is the wiring somewhere or something to do with the coding of the car? I have included screenshots of a recent ISTA readout that shows issues with the ASD unit. I have no idea if that would affect current audio.
Any help that results in the remedy of this problem will be much appreciated. I am currently driving with a Bluetooth speaker to keep my sanity.
[ATTACH][ATTACH]Name:  image0.jpeg
Size:  348.8 KB[/ATTACH][/ATTACH]
f30post
