02-26-2017, 02:47 PM | #1 |
Rep 8
Increase car performance?
Some factors that increase car performance:
02-26-2017, 03:07 PM | #2 |
Beefcake
3769
Rep 711
Stickers
15
///M Power-Belgium63219.50 RABAUKE4656.00 Aatish3458.00 shoei7779.00 The Choosey begger71933.50 Nkc1600.50 m5james431.00 fecurtis3262.00 The Chaddening11585.00 Biorin2784.50 mantis276.00 Antetokounmpo1549.50 Aust350z244.50 silvergray5452336.50 trvplvrdBOI707.00 |
02-26-2017, 03:14 PM | #4 |
Rep 24,651
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
02-26-2017, 03:19 PM | #5 |
Rep 350
Each car is a unique situation, you can't just blanket statement that all cars will benefit from an air filter. Tires, maybe. Or with turbo cars, an ECU flash. The one part that is the performance bottleneck on a car will net you the highest performance gains, and so on down the rabbit hole.
02-26-2017, 03:21 PM | #6 |
Rep 5,776
JB4 + downpipe+ Ethanol.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
02-26-2017, 03:26 PM | #7 |
Rep 3,211
Depends on what attributes of "performance" we are talking about but imo overall performance would mean many line items together properly upgraded & configured/tuned together..
for the application.. ie.. you could put the tune on the ECU garnering more power but be unable to efficiently put it to the road cause yer tires suck or running around a track at sustained high speeds experiencing brake fade or overheating |
kevin6521.50 |
02-26-2017, 03:28 PM | #8 |
Rep 11
02-26-2017, 03:34 PM | #9 |
Rep 3,323
Tires are the single most important factor. The oEM Bridgestones on mine were very good but now I use Michelin SS.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
kevin6521.50 |
02-26-2017, 04:45 PM | #11 |
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
A car engine is an air pump, the more air/fuel you can get through it the more performance you get. It needs to breath, so intake, exhaust and timing. This can be achieved by a number of things. Throttle body or carb, headers, valves and timing will do that. Tires are a handling issue as is suspension, firmer shocks, stickier tires and better breaks all will help with performance, but you really want to get the engine to breathe, this is a bigger issue and more easily addressed with older cars but will get you lots of bang for the buck.
02-26-2017, 06:34 PM | #13 | |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
1. Driver 2. Tires 3. Brakes (Fluid, Pads, Lines, will do for most street driving. BBK-extreme) 4. Chassis upgrades (stiffer) 5. Driver 6. Intake - higher flow air filter or ram air, etc. As long as it's cool air. 7. De Cat/higher flow Cat and replace all three exhaust sections. 8. Driver 9. Chip. 10. Driver This should yield a higher performing vehicle. The most significant improvements will be with Driver Mods, Tires, and Brakes.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
02-26-2017, 07:32 PM | #14 |
NOOB
1601
Rep 1,356
Reducing weight. Take away all unnecessary things like seats, airbags, AC, insulation, etc. Reduce unsprung weight ie wheels, brakes, etc. Best tires you can afford and improving the driver or just be a dick and get a GT3RS.
03-04-2017, 11:18 AM | #16 |
Rep 216
03-04-2017, 09:20 PM | #17 |
Rep 9,004
I know I'll be in the minority here, but I don't think chassis stiffening has any emperical evidence to support its supposed benefits.
But driver and tires would be the best. |
///M Power-Belgium63219.50 Antetokounmpo1549.50 |
03-04-2017, 10:27 PM | #19 |
Rep 5,776
That would be available in another country--not in pseudo third world countries.
03-05-2017, 01:21 AM | #20 | |
Know's a guy that know's a guy...
5637
Rep 1,905
What I have found to add the biggest bang for the buck is a set of ///M badges.... |
03-05-2017, 07:23 AM | #21 |
Mike: Everyone's Pal
2042
Rep 2,972
Drives: F80 M3
drives: "sport car"
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
