E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Radio Interference
      10-20-2020, 10:53 PM   #1
flameo17
Drives: 2006 330i
Radio Interference
I got a 2006 330i with the base radio with no idrive and i get interference only on the FM radio. Was wondering if i could get any help in figuring out what causes it.
the interference only occurs when the engine is running and i’m either idling or have my foot on the gas. if i’m already going at speed and, while staying in gear, i completely let off the gas (closed throttle) the radio interference disappears until i put my foot back on the gas. same thing happens when in neutral except the interference comes back once the engine hits idle. i feel like it’s a grounding issue with the fuel system or throttle body but i’ve got no idea what to look for or what i need to do to fix it
      10-21-2020, 01:45 AM   #2
ctuna
Drives: 325xi 06 wagon MT
I would try reseating the radio connectors first.
      10-22-2020, 03:14 PM   #3
flameo17
Drives: 2006 330i
just tried doing that, popped the radio out and took out and reset the connections and made sure the wires were seated, but it’s still the same; radio works fine in accessory mode but gets interference whenever the engine is running
      10-27-2020, 05:29 PM   #4
flameo17
Drives: 2006 330i
Just to add, the interference doesn’t start until around like 5 seconds after the engine is running, and it stays for a couple seconds once the engine is turned off
update: ok so the interference starts a couple seconds after the engine is running, but actually goes away immediately after the engine is turned off. the sound does not rise with engine rpms and is pretty consistent in volume and length
      10-28-2020, 08:59 AM   #5
opjose
opjose's Avatar
242
Drives: 335xi
Has any work been done to the ignition/injector systems?
      11-02-2020, 05:25 PM   #6
flameo17
Drives: 2006 330i
not to my knowledge, but when i bought the car used, it looked like it had been sitting for a while, idk if that’s relevant
      11-03-2020, 04:22 PM   #7
opjose
opjose's Avatar
242
Drives: 335xi
Have you checked the condition of the engine ground strap?
Those are notorious for rusting out which could cause interference issues?
      11-10-2020, 11:57 AM   #8
J0K3R5
J0K3R5's Avatar
Vatican City State
406
check your earth straps
Help yourself Software part II, read post 1 : https://www.e90post.com/forums/showt...7#post27890067
      11-10-2020, 02:49 PM   #9
david in germany
Drives: 118i, 335i and 328i
Ok, this will sound funny but, do you have a phone charger/ usb charger plugged into the cig lighter? If you do try unplugging it and see if the interference is still there.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      04-25-2024, 07:19 AM   #10
KSutherland67
Drives: '13 335iXdrive, MB CLA250
I found a post where a guy reset his radio and that did the trick so i tried and it seemed to work on mine.
Tags
interference, radio issue, radio professional
e90post
