12-12-2021, 05:51 PM | #1 |
Rep 14
Error reading code
Not sure if I’m right category so apologies in advance. Anyone have any idea why Bimmer code won’t read my front right headlight. Comes up with “Error while reading coding data” Car is an X2 2018 2.0’sdrive.
Thanks Andrew. https://f48.bimmerpost.com/forums/at...1&d=1639353043 Last edited by andylew0; 12-12-2021 at 05:52 PM.. Reason: Added info |
12-17-2021, 12:58 AM | #2 |
Rep 1
Bimmercode cannot do OBD-II diagnostics or clear codes, but the dongle that it needs can be used with other mypascoconnect software since that is myloweslife actually what it is intended to be used for
12-17-2021, 07:46 AM | #3 | |
Rep 14
I’m aware of that hence I also have BimmerLink. Bimmercode reads the left hand headlight. But not the right. So basically I can code brightness on the left headlight but not the right. Bimmer are aware of the issue. And are looking into a solution. As for some reason the right hand module is different. |
02-17-2024, 04:58 PM | #4 | |
Rep 1
Update for solution
02-18-2024, 04:13 AM | #5 |
Rep 14
