05-04-2023, 10:59 AM | #1 |
7404
Rep 10,214
What's your pressure washer setup?
Pressure washer (gas or electric)- Ryobi, Active, Sunjoe, Kranzle?
Hose - Uberflex, flexzilla? Wand - MTM? Curious to what you guys are using. I plan on upgrading my setup for maybe weekly or biweekly use so definitely don’t need a high end setup. |
05-04-2023, 11:27 AM | #2 |
Rep 1,001
Drives: 2007 Z4 M Coupe 2012 e93 M3
Pressure washer- just replaced my cheapo SunJoe with Active 2.0. I could see significant difference when using it for the Foamer.
Hose - MTM Kobrajet Wand - MTM Hydro Acqualine. Last edited by Pheonix; 05-04-2023 at 12:41 PM.. |
05-04-2023, 11:52 AM | #3 |
Rep 309
pressure washer : kranzle 1322ts
hose - kobrajet wand - mosmatic |
luckylingy3233.50 classic_erik2808.50 |
05-04-2023, 12:21 PM | #4 |
Rep 125
I'm using a cheap electric one ($100 - $120 range) from amazon. Also bought a cheap nozzle from amazon to replace the long wand. No complaints, works great. Doesn't throw as much foam as the nice ones i see on youtube detailing vids, but definitely sufficient for me.
05-04-2023, 12:26 PM | #5 |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I have a SunJoe but my favorite is this little red Hyper Tough pressure washer I got at Walmart for $60. Not too powerful and easy to setup/put away/move around.
05-04-2023, 12:32 PM | #6 |
dances with roads
4722
Rep 4,096
AR Blue Clean. Comes with foam gun, hose is supple enough for me. I use all of the stuff that came with it. I think they may have a newer model out.
https://www.amazon.com/Blue-Clean-BC...02&sr=1-4&th=1 EDIT: to clarify -- I have model BC383HS. |
BMW AD30.00 |
05-04-2023, 02:53 PM | #7 |
Rep 36
Pressure Washer Ryobi 1800 PSI - https://www.homedepot.com/p/RYOBI-18...1802/317623149
Hose PWACCS (50 ft) kink resistant, comes w/ (2) quick connects - https://www.amazon.com/PWACCS-Pressu...10&sr=8-3&th=1 Wand Sooprinse gun, added a quick connect - https://www.amazon.com/Sooprinse-Pre...03&sr=8-3&th=1 Foam Cannon Harbor Freight, changed orifice to 1.1mm - https://www.harborfreight.com/pressu...non-58131.html - https://www.amazon.com/Mingle-Cannon...s%2C122&sr=8-4 |
05-04-2023, 05:02 PM | #8 |
Rep 349
Pressure washer: Kranzle 1122tst
Sprayer: Mosmatic swivel Wand: Mosmatic Cannon: MTM PF22 Tips: Mosmatic and MTM Water Filter: CR Spotless mounted to wall Fittings: MTM SS Garden Hose: SS Jumper hose and Eley garden hose and Eley spray nozzle |
05-04-2023, 05:40 PM | #9 |
Rep 509
Pressure washer...BigBoi Washr Flo with the optional commercial grade hose upgrade
Stubby gun...MTM SGS28 with Carscope premium 25° and 40° nozzles Wand...Mosmatic Foam cannon...MJJC Pro V2, MTM PF22.2 and an Autobrite Direct foam cannon (probably not available outside the UK) |
05-04-2023, 06:04 PM | #10 |
Rep 3,804
Ditto
Patton2502939.50 Pheonix377.50 shimmy232350.00 Charles B59.50 FZZF0.00 Clark_Kent2227.50 classic_erik2808.50 |
05-04-2023, 06:04 PM | #11 |
sportscars only
3244
Rep 3,195
I just use this all-in-one. Great for me.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
05-04-2023, 06:23 PM | #12 | |
Rep 68
05-04-2023, 06:46 PM | #13 | |
Rep 36
I would just Google search the strengths of the various nozzle fittings before use. |
PJ196042.00 |
05-04-2023, 06:48 PM | #14 |
Not great. Not terrible
7445
Rep 2,700
One of these hand held battery operated jobs. It's perfect for my needs, takes up little room, and uses the same batteries as my tools.
https://www.homedepot.com/p/RYOBI-40...052K/318615872
Current: 2024 BMW X3 M40i.
05-04-2023, 08:59 PM | #15 |
OG M2 🖤
36
Rep 11
Pressure washer: Original Active
Hose: 50' no name kinkless from amazon w/quick connects Wand: Cheap gun w/swivel adapter + knock-off MTM extension I'm patiently waiting for some of the cheap stuff to die/leak to upgrade but they're holding strong so far |
05-05-2023, 06:16 AM | #17 |
Rep 781
Honda gas powered, 2000 psi, 2.5 gal per min.
The compressor has an adjustable regulator so the pressure can be dialed back if needed. Also a Maxshine foam cannon.
2008 E86 M coupe
05-05-2023, 08:10 AM | #19 | |
Rep 125
05-05-2023, 08:55 AM | #20 |
Rep 36
icj_45e108.00 Luigi524TD34.00 |
05-05-2023, 12:19 PM | #22 |
7404
Rep 10,214
I thought the Active 2.0 was just on preorder still?
