Full Off Road build guide for 335d
11-08-2016, 09:37 PM | #1 |
Rep 77
I've had my car for about 1 month and 1200 miles and have been trying to gain as much knowledge about turning it into a reliable, efficient, torque monster (that it deserves to be). Here are my findings:
THINGS OF ISSUE: CBU - Carbon Build Up (Cleaning) EGR - Exhaust Gas Recirculation DPF - Diesel Particulate Filter SCR - Selective Catalytic Reduction DEF Tank Removal- Diesel Exhaust Fluid Tank Removal Swirl Flap Delete Vacuum Hoses Harmonic Balancer THINGS TO BUY: Boost Pipe Upgrade: https://www.ecstuning.com/b-forge-pa...FQdWDQodvkwIvw or http://www.fixmyvw.com/bmw-335d-upgr...-intercoolers/ Turbo Back Exhaust: PM Iaknown for his exhaust or http://www.fixmyvw.com/scr-delete-ki...d-p-l-exhaust/ EGR Delete Plates: http://www.fixmyvw.com/bmw-335d-and-...ock-off-plate/ EGR Race Pipe: http://www.fixmyvw.com/egr-race-pipe...5d-and-x5-35d/ (alternative to deletes for full removal of EGR system) Swirl Flap Delete: http://www.fixmyvw.com/swirl-flap-de...5d-and-x5-35d/ Intercooler: https://www.turnermotorsport.com/p-2...oler-e90-335d/ Tunes: http://bimmerperformancecenter.com/bpc-diesel/ or http://www.fixmyvw.com/bmw-335d-ecu-...g-performance/ New Vacuum Hoses 3.5mm: https://www.amazon.com/HPS-HTSVH35-B...mm+vacuum+hose Meth/Water Injection: https://bimmer-performance-center.my...tem-for-diesel Harmonic Balancers: https://www.ecstuning.com/BMW-E90-33...ngine/Pulleys/ Suspension: Ohlins BMS MI00 Road and Track Coilovers Good Links: http://www.e90post.com/forums/showthread.php?t=1089933 talks about EGR SCR and DPF http://www.e90post.com/forums/showthread.php?t=1255573 vacuum line tips and tricks http://www.e90post.com/forums/showth...=969420&page=2 Iaknown EGR delete plate install starts on post #35 Swirl Flap delete plates installation (Also a good time to replace vacuum lines and intake gaskets) I hope this post isnt going to aggravate people due to some redundancy but I was hoping to create a One Stop Shop sort of thread for all the new 335d owners that should be rolling in. If anyone has anything to add ie. links to other threads or common knowledge on tools required for certain installs I will update the post to include them all. Also, any top players and their locations for tunes/dynos or just handy mechanics that have seen all parts of the 335d. Thanks guys! Last edited by Bimmerguy1987; 04-14-2017 at 07:33 AM.. |
11-09-2016, 03:13 AM | #2 |
Warrant Officer
375
Rep 1,341
A link to JR's tune would be good. Yohz made a thread that has links to more threads regarding the vacuum issues so if you find that, throw it in there as well.
PM Ianknown about exhausts, he knows a good place to get them.
Deleted, ATM I/C and tuned by B.R.R.
11-09-2016, 08:51 AM | #3 |
Rep 1,157
Those EGR delete plates keep the EGR cooler in place, but block it off. The EGR Race Pipe removes the cooler completely. You use one or the other, not both. I know people that just run the block plates to keep the engine looking stock. PM Iaknown about exhausts and block plates. Great guy, and very helpful.
iaknown427.00 windsearcher0.00 |
11-09-2016, 09:12 AM | #4 | |
Rep 1,578
11-10-2016, 08:28 AM | #6 |
Rep 77
Sorry haven't updated post yet from suggestions but I had PRK done yesterday and healing up. I will update. Also, BPC is currently back doing tunes for cars.
11-10-2016, 01:36 PM | #7 |
Rep 3,558
stolympiakos6.50 |
11-13-2016, 12:47 PM | #8 |
Rep 18
11-13-2016, 12:52 PM | #9 |
Rep 3,049
Drives: 2009 BMW 335d
Add upgraded brakes and suspension to the OP as well.
12-01-2016, 11:32 AM | #12 |
Kind of a Big Deal
167
Rep 857
Is the swirl flap delete really desirable on the M57? I have read of problems with flaps breaking off on the Euro variant; is it also a problem on the U.S. models?
12-01-2016, 11:40 AM | #14 |
Rep 233
Great thread!
Just wanted to mention that we have a Charge Air boost pipe for $129 that includes all seals and better quality clamps than the other pipe that you had posted. http://www.fixmyvw.com/bmw-335d-upgr...-intercoolers/ |
Rods335D15.00 windsearcher0.00 |
12-29-2016, 07:37 PM | #16 |
NY BRAVEST
47
Rep 231
Is there an aftermarket exhaust manifold out there for or D's. I see in Europe, of course other D models do. Im sure the cast manifold is all caked up with Carbon and restricted. Can't be too difficult to copy the stock mani with bigger SS tubing or if it's even worth it?
03-27-2017, 08:13 AM | #20 |
Rep 221
i will install the catch can.
i blocked off the egr and it put my D into limp mode. does it require a tune? codes were P401 and p402 - either not enough Exhaust Gas or too much... i think the p402 put it into the limp mode how about meth injection? |
03-27-2017, 09:06 AM | #21 |
Rep 1,157
I blocked the EGR as well and never got limp mode. Jest got a stupid yellow light on the dash at all times.
