12-28-2014, 01:23 PM | #23 | |
Rep 648
Plus mounting cost.. The Quaife is great fun. If the BMW LSD is Easier to handle then it's very easy !
Ist der Motor kalt, Gib ihn sechs ein halb.....
12-30-2014, 05:37 AM | #25 |
Rep 648
Indeed, but very much worth it. (Whether you want MPLSD or Quaife).
All BMW's should have this, but I guess it's one way to make the price ie of the F-model cheaper thus more competitive against Mercedes and Audi. /Krelle
12-30-2014, 03:35 PM | #26 | |
Rep 681
Just this afternoon I did a lot of drifts on the snow and I found out that eLSD in DSC Off program cannot manage traction properly on that condition. Much better DTC (in Sport+ or Traction program): at law speed on snow/ice it permits you to enjoy as well oversteering I wish I will buy an LSD for may 435i!
BMW M3 G80 Isle of Man
01-05-2015, 11:28 AM | #27 |
Rep 469
Has anyone gotten the MPLSD yet? Is there a difference in how the car handles when driving normally? I assume the handling on the track will be improved (1-2 times a year).
I am considering the MPLSD together with the 18" M performance brakes but only want to do the upgrade if I feel the difference.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
01-06-2015, 09:17 AM | #28 |
Rep 681
No, I think that all handling when driving sporty would improve, not only on track!
For example, I'm used to driving in mountains and I miss a real LSD on short corners
01-07-2015, 04:05 PM | #29 | |
Rep 648
You get improved cornering, acceleration out of corners, lesser risk of turning 360 under hard acceleration in wet condition, lesser tire wear (but hard to prove..), less wear on the rear brakes and bigger smile ! /Krelle
Lancelot571.50 |
01-08-2015, 07:58 AM | #30 | |
Rep 4,323
It's winter here, so even more fun/difference. You'll notice it just turning in a parking lot and accelerating hard out of a turn...the brakes and LSD I both have, and are both worth it.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
01-08-2015, 01:04 PM | #31 |
Rep 469
Thanks for the information. How about when you just cruise? Is there any difference in the way the car behaves?
01-08-2015, 02:09 PM | #32 | |
Rep 681
Another question: with M Performance LSD installed are there any changes in the indication on control display? M Performance LSD gives maximum benefits in DSC Off, isn't it? But I guess also in Sport+ program, no?
02-18-2015, 09:49 AM | #35 | |
Rep 648
/Krelle
03-01-2015, 09:57 AM | #36 | |
2006 TIME Person Of The Year
9720
Rep 6,445
03-02-2015, 06:21 AM | #37 |
Rep 603
In the OT Picture under FAQ it is mentioned that Radial Shaft Seals and Driveshaft Retention Clips are also needed.
Can someone please tell me the part numbers so I can order them also. Retention Clip I think is 33131214961, but what's the Radial Shaft Seal number? Thanks. |
03-03-2015, 05:32 PM | #38 | |
Rep 648
Also a good upportunity to overhaul the brakes..
03-04-2015, 05:06 AM | #39 | |
Rep 603
Krelle Do you eventually have an install guide of the LSD, so I could prepare myself of what the working steps are? Which parts/screws on the axel side have to be removed? Recommended torque info? Special BMW-Tools needed? As I'm planning to do it in a friends VW Garage it would be helpfull to know in advance, so we can get organized. thx in advace! |
03-06-2015, 01:19 PM | #40 | |
Rep 648
However all tools and specific torques all referat to bmw manuals which sucks. I Think I have some pics somewhere as well. One tool we had to producere ourselves. /Krelle
03-23-2015, 12:56 PM | #41 |
Rep 469
Got the MLSD installed today at the local BMW garage. It took extra time because the old differential was really, really hard to get out. The new was a complete replacement, so install was easy. "Just" remove the old and install the new.
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 Last edited by Feddersen; 03-23-2015 at 12:56 PM.. Reason: Spelling mistake |
03-23-2015, 01:36 PM | #42 | |
Rep 3,958
Also, I wonder how often these LSDs will need to be rebuilt. |
03-23-2015, 01:55 PM | #43 | |
Rep 648
Lucky you that bmw has fixed Price on this work. Which garage installed the diff?
03-23-2015, 02:02 PM | #44 |
Rep 469
BMW had apparently added Loctite to the drive shaft. The tool that was intented to remove the drive shaft actually broke during the removal and we had to cut the bolt that held the drive shaft and the differential together in order to get the differential out.
