12-17-2016, 12:38 PM | #1 |
Rep 258
request: how to remove tree sap from car paint
hi, what are some of your methods to removing tree sap from car paint? i got some really thick ones that's stuck on like crazy glue.
12-17-2016, 12:51 PM | #2 |
Rep 762
This is easy. Get some dry gas. I think Isopropl alcohol would work also, but we use dry gas in the paint dept I work in. Really thick sap should place a soaked towel over and let sit. Might take several attempts as the alcohol will evaporate. Use a soft paper towel and be patient. I see a lot of damaged paint from sap removal by owners not taking the time to do it right.
12-17-2016, 03:30 PM | #4 |
Rep 500
Put isopropyl alcohol on a small towel. Apply to the sap and let it sit for a minute. Dab and apply more as necessary. After its all gone reapply some wax to the area you cleaned. Super simple and safe.
I've also seen people use steel wool, fine grit sandpaper...really bad. It's so easy with the IPA. |
12-17-2016, 03:37 PM | #6 |
European Editor
10640
Rep 22,992
I would try these methods first...
Soap and water and a sponge... Clay bar... Isopropyl Alcohol... "Bug and Tar" remover... All the above work well. Just don't forget to apply some wax/sealer afterwards.
