Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      08-28-2017, 02:47 AM   #1
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Vinyl wrap with Comfort Access?
Does it affect the comfort access unlock and locking on the car on the handle? Does it still work?
      08-28-2017, 10:28 AM   #2
turbo_joe
turbo_joe's Avatar
1640
Drives: 2012 M3 Coupe
Mine still works fine after wrapping my car.
      08-28-2017, 02:49 PM   #3
jinda
jinda's Avatar
19
Drives: 2013 X1 xDrive35i M Sport
Mine is working fine. The thing that's affected for me are the front parking sensors so I had to cut out the round holes on the bumper.
What's weird is the rear sensors doesn't act that way so they are covered over by vinyl.
2013 X1 x35i M Sport
Past: 2011 Mazda CX7 AWD Sport | 2004 BMW 330i ZSP/ZPP | 2008 Hummer H3 | 2005 Honda Civic VTi | 1997 Honda Civic ESi | 1996 Nissan Sentra SS EXi
      08-28-2017, 04:24 PM   #4
turbo_joe
turbo_joe's Avatar
1640
My rear sensors work fine as well. No front sensors for me
      08-28-2017, 05:22 PM   #5
TheMidnightNarwhal
Ah right, the parking sensors. Does it still look ok with the holes cut? Granted, it depends on your original car color.
Do you know if paint would affect them to? I would say yes?
      08-28-2017, 05:54 PM   #6
jinda
jinda's Avatar
19
My original color is black so it went OK since I have black caps covering the plate holes too.
Not sure with paint. Not even sure why my front have issues while the rear is OK.
      08-28-2017, 06:26 PM   #7
TheMidnightNarwhal
Ok thanks.
I'll probably still wrap the car I'll get. Worse that can happen they'll just won't work right.
      08-29-2017, 08:06 AM   #8
jinda
jinda's Avatar
19
Ok thanks.
The issue is actually the sensors thinking there are obstructions so it keeps on beeping while you are reversing or using the PDC.
Yeah try to see if you'll get the same problem. Maybe you won't. In case, maybe you can try to cut the circumference of each wrap on the sensor but don't remove the wrap. Just stick it down. Normally the sensor is going off when the wrap is not sticking flat since the sensors are a bit depressed creating some tiny space between wrap and face of the sensor.
