04-16-2020, 01:38 PM | #1 |
Rep 159
Home Theater Speakers
Trying to decide between Klipsch RP 8000F and Elac Uni Fi UF5. Does anyone have these speakers and what your honest opinions are in this? Elac I might have to spend more and get power amp like Outlaw 5000.
04-16-2020, 01:50 PM | #2 | |
Rep 600
I think you would be happy with Klipsch. |
Black Sunshine39.00 |
04-16-2020, 03:24 PM | #3 |
Rep 45
No experience with the Elans. Like Nuckle already said the Klipsch RF series have always been a great buy. Very durable if driven hard, and very efficient with lower power. Only thing I will mention, at least on the older series is that they can come across as "bright". Normally not an issue for male ears or if being used as a mix for music and home theatre as you are looking to do. I used to work at a higher end AV store in the past and loved them. I actually have a pair of their large outdoor speakers for the yard.
If you don't upgrade to the Outlaw, what are you planning on powering them with? |
04-16-2020, 03:46 PM | #4 |
Rep 159
If I purchase the Elac speakers they need more power since its a 4 ohm speaker, that would be the only reason to get the Outlaw power amp. I am kinda gearing towards the Klipsch since Amazon has the piano black finish for $517 right, at Best Buy its pricing at over $800. I have a decent Denon amp right now so the Klipsch speakers would be fine. Lots of good reviews on the Reference Premier series. Elacs are good too but it needs more power.
04-16-2020, 04:08 PM | #5 | |
Rep 600
04-16-2020, 09:39 PM | #7 |
Rep 600
04-16-2020, 10:04 PM | #8 | |
2006 TIME Person Of The Year
9720
Rep 6,445
1. Will you be using a sub or just the two speakers? 2.Do you already own a receiver; if so what one? 3. How big is the room? 4. How far will you be from the speakers? 5. Is this your first set of "real" speakers? 6. How would you describe what you're seeking in these speakers/this system?
Murf99314114.00 |
04-17-2020, 12:17 AM | #9 |
Rep 2,476
I don't like Klipsch, but between your 2 choices I'd go Klipsch based on 3 specs. Efficiency, woofer arrangement/extension and power handling.
The Klipsch trump the Elac's by 13dB @2.83v/1m, that's quite significant. I'm a high efficiency fanatic when it comes to speakers, something that many aren't, but they tend to be much more dynamic. Dual 8" woofers on the Klipsch should result in a more authoritative low end, which the specs show with the Klipsch at -3dB at 32Hz, and the Elacs at 42Hz - plus the Elacs don't specify if that 42Hz spec is at -3, -6, -10dB... Personally, I don't like subs for music, so that extension on the low end is important, to me. Klipsch have an RMS power rating of 150w and a peak power handling of 600w. Elacs are rated at 140w peak - couple that low power handling with their inefficiency and...no, thank you. This, of course, is all based on paper specs. Sometimes speakers sound better/worse than their specs suggest. Your intended use and needs may also negate any of the above. Can you audition either of them anywhere in person? |
04-17-2020, 06:40 AM | #10 |
9720
Rep 6,445
The Klipsch and Elac are very different loudspeakers. While I wait to learn more about the OP's specific application, I'll suggest a third option to consider... KEF Q series. A Q550 is right there in price with the other two options, and is clearly an excellent performer.
Q series come in black, white, and my preference... walnut. https://us.kef.com/catalog/product/v.../category/219/ https://www.soundvisionreview.com/hi...f-q550-review/
04-17-2020, 08:12 AM | #11 |
Rep 3,988
I have a pair of Elac Debut 2.0, they are okay, nice that they are 3way so they sound decent in stereo mode.
I would say they are a good mid-priced option. What really enhanced my setup was a good sub, I got a Klipsch R-12SW. It added a whole new dimension I never had before with my small little Yamaha sub.
04-17-2020, 11:05 AM | #12 |
9720
Rep 6,445
Another path would be as follows...
We at KEF have our Q150 bookshelf speakers at 1/2 price until the end of the month. Let's call that $300 a pair... Add a KEF "KUBE-10b" subwoofer at $650 and you're at $950. Potentially you'll need to buy some speaker stands too, but my thinking is this setup will allow an upgrade path to a surround system in the future where you'll repurpose the Q150s as your surround speakers and you'll already own a sub. Also, i personally like the look of stand-mounted loudspeakers, but admittedly that's subjective.
04-17-2020, 11:07 AM | #13 |
Rep 316
04-17-2020, 08:14 PM | #14 | |
Rep 3,241
Subs provide so many advantages. 1) They take the strain off of your main amp in not having to drive the bass in your mains. You're effectively biamping your system. This is provided you use the high pass filter built in to your sub or implement it at your source processor. 2) Placement of your mains is not always the best placement for the best bass performance in your room. With a sub, you can move the sub to a spot that provides the best bass performance taking into account your room characteristics and modes. 3) Subs are optimized to perform best at the lower frequencies. I have two subs in my main system: a Velodyne HGS15II and a Velodyne DD18. The two subs are integrated seamlessly with my B&W N804 and N HTM1s. A friend of mine who used to manage the area HiFi specialty store auditioned my system. He was impressed at how he could see them but they didn't stick out and make themselves known. The output of the subs were just a natural extension of my main speakers. When you achieve this with good bass extension and no distortion, you have your system dialed in correctly. |
04-17-2020, 08:42 PM | #15 | |
Rep 2,476
You've made some good points, and that DD18 you've got is quite the performer. Subs can be a benefit if your mains can't do what you need them to, but there's so many downsides that I'd much rather my mains be able to handle the low end needed for music. Things like group delay, time alignment and phase issues...yes, tuning can help, but the vast majority of people don't understand what it takes to do that properly and automated methods like Audyssey are a joke, IMO. Now, I hesitate to say this because 96% of the population would think I'm crazy...the mains in my home system consist of dual 15s per side as woofers(not subwoofers), a 10" mid-range and a compression driver on a 15"x30" waveguide for the HF. They're part of a 5.1 system that is fully active using a BiAmp TesiraServer as the DSP and each driver in the whole system has a dedicated power amp channel. All of the drivers are high efficiency except for the subs which are 5 18s, again on an amp channel per driver, but they don't get turned on unless I'm watching a movie since the 4 15s in the mains handle music quite well. Anyway, I know that's way beyond any reasonable individual thinks is needed, but it's one of those things that once you experience it, you can't go back. Anyway, don't want to derail the OPs thread with my lunacy, but I am a big proponent of high efficiency speakers. Which is not to say that low efficiency can't sound good, or that all high efficiency models sound great, but that's the first spec I look for. Spec 2 is driver sizes and extension on the low end. Last edited by Emilime75; 04-17-2020 at 09:09 PM.. |
04-18-2020, 06:14 PM | #16 |
"Salud"
13847
Rep 4,675
Drives: F01 & F15 / Mineral White
I have Klipsch in my Home Theater for the past 2 years and they absolutely Thunder while providing plenty of highs and mids. Highly recommend.
04-20-2020, 09:32 AM | #18 | |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
04-20-2020, 09:36 AM | #19 |
Rep 3,241
LOL. Just did.
