11-29-2020, 09:16 AM | #1 |
Rep 1,146
Chili for Tacos?
So I'm having problems with making mince for tacos.
the end result is tasty and full of flavor, but has loads of liquid when it settles down. I want something a bit more "together" with some liquid, kinda like a jam or ketchup consitancy. (how I cook) fry onions in a dash of oil, add (beef) mince (medium), fry, add a small jar of tomatoe/seasoning.. maybe throw in a couple of spices and garlic... had thought of the dry season, but not sure if I should add any tomatoe puree etc any ideas ? txs |
11-29-2020, 09:18 AM | #2 |
Rep 1,146
maybe the mnice I'm using is wrong
should I use lean ground or extra lean ground ? |
pennsiveguy3552.00 |
11-29-2020, 01:43 PM | #6 |
Rep 647
Thin chili is a result of many things. 1, when your sweating the vegetables ensure to sweat until almost dry. Add your spices to the vegetables and toast them. Then sprinkle 1-2 to flour and stir until it becomes really tight and pasty. Add tomato paste. This is also a thickening agent. Add your stocks and cooked meat and reduce until it tightens. Flour will give a cleaner taste vs slurry. The key is truly reduction and rest time. Once its reduced and starting to tighten, let it just set for 10 more minutes and the flour inside will continue to bind it together.
nazali1297.00 |
11-30-2020, 11:00 AM | #7 | |
Rep 1,146
this is TOTALLY different to what I do LOL
I'll give it a try as well as the corn starch tip Quote:
11-30-2020, 11:03 AM | #8 |
Rep 1,146
one other thing, I'm finding I'm making too much,,, is it better to half the fresh mince and freeze it OR cook the whole lot and freeze half the cooked lot or friderate it
does freezer mince go mushy I'm buying fresh raw mince (beef) btw any other type of mince such as pork or mix of meats ? |
11-30-2020, 12:21 PM | #10 |
Rep 1,965
Curious as to what part of the south OP is from.
11-30-2020, 12:23 PM | #11 |
Rep 1,397
11-30-2020, 12:51 PM | #12 |
Rep 1,965
Well.....this, along with a few other red flags, is what alerted me to the OP being located in the south. I'm "here" so I knew she was too.
fiveohwblow3633.00 |
12-03-2020, 08:52 PM | #17 |
Rep 1,146
Hi Guy's
so today was taco night, I made 2 major changes. 1> extra lean beef 2> Corn starch (mixed with a bit of water) directly into the mix After cooking, I really let it simmer and cook, but DD was starving so served it up. I think also it needed some rest time to thicken as well once off the heat By our 2nd taco, it was just right ! I'll keep playing with this, I'm finding the "taco" sauce jar is pretty bland so I'm going to try and give it a bit of favor and play around thanks ALLLLLLLLLL I found the mince was a MUCH better consistency and not as much OIL puddles I also found you need to leave it to cool down so it thickens up a bit, previous it didn't thicken, and left overs over night had big patches of Lard all over it Yeah much better, So I'm heading in the right direction now |
Murf99314114.00 |
12-04-2020, 09:13 AM | #18 | |
Rep 265
nazali1297.00 |
12-04-2020, 09:41 AM | #19 |
Not willing to take advice
4046
Rep 1,527
It's Taco Tuesday - not Taco Thursday, so that's part of the problem right there.
Just trying to help Personally - would never use extra lean, would seem flavorless. 80/20 at the most lean...be sure to drain.
Proud owner of 4 Turbos and 1 Supercharger
12-10-2020, 03:09 PM | #20 |
Rep 1,146
yeah the beefy flavor was not as good I did note, I might actually mix the corn starch with some beef stock,
but as I said the left overs were very palatable and not needed to be separated from lumps of congealed fat LOL I wanted to replicate it today, next week might try lean instead of extra lean lol taco Tuesday, that's what my daughter says "it's supposed to be taco Tuesday not Thursday" LOL |
12-10-2020, 03:32 PM | #22 |
Rep 1,062
Drives: F15 xDrive50i M-sport
Drain off most or all of the liquid. If you need something to thicken it after that, a dab of refried beans will do the trick and won't turn it white like corn starch and won't add a strange taste that's out of place.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
