10-29-2019, 10:43 AM | #1 |
Rep 83
Brake Force Display
Has anyone successfully coded in the flashing brake force display in a 2 series? The option is there in the REM module but it is looking like some expert mode coding is required.
10-29-2019, 11:45 AM | #2 |
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
I found out my car (2017 M240i) has it - stock - when me friends pointed it out to me under heavy braking.
10-31-2019, 03:16 PM | #4 |
Rep 83
yea there is no way at stock they were flashing like what the brake force display code is suppose to implement. Most chassis's seem to have this code work in the main interface in the REM and FEM module but didn't do the trick in my f22.
FEM - Brake Force Display "Flashing" REM - Expert Mode - 3062 LCE Lamp Mapping 1 - Mapping Brakedforced (L and R) Output - bl-r. But didn't work for me. but regarding the above comment, it was definitely the secondary lights that light up indicating heavier braking. Last edited by JG_Media9; 11-01-2019 at 02:32 PM.. |
10-31-2019, 11:09 PM | #5 |
Rep 5,262
11-05-2019, 08:33 AM | #6 | |
Rep 1,290
11-08-2019, 08:38 PM | #7 |
Rep 348
Any update? Haven't gotten it to work either..
Pure800 - DS2 HPFP - Nostrum S1 - ER Catless DP - Remus Non-Resonated Catback - BM3 Flex Fuel Kit - Ross V1 VTA PCV - Custom Tunes on MHD/BM3 - xHP Stage 3 - TCKline SA/DA Coils - Apex ARC8s - Vicrez Carbon Fiber CSL Trunk - ALP Laser System - Escort Max 360c with Blendmount + more... | IG: kianf22 |
11-08-2019, 10:45 PM | #8 |
Rep 267
Me neither. Changed all plus 3060 / essaktivierbarer ausgang to blinking (saw in f30 video comments). Still nothing. Locking up.. still doesn't flash
11-09-2019, 03:13 AM | #9 |
Rep 348
Is yours an LCI. Maybe we have to do something different ?
11-10-2019, 02:37 PM | #11 |
Rep 348
Maybe LCI requires different/more coding ?
11-11-2019, 08:38 AM | #12 |
Rep 1,290
11-11-2019, 10:46 AM | #14 |
Rep 83
i gave these instructions from the picture to a friend who has the same car as me (2015 m235i) and he confirmed it worked for him. still same for me with haven't gotten it to work. I am going to try coding back to "area enlargement" and then trying again.
11-12-2019, 08:36 AM | #15 |
Rep 1,290
I just followed the instructions in the video and did everything the exact same as he did. make sure once you make the coding changes in bimmercode that you hit the coding button or else it won't save the changes.
11-12-2019, 04:42 PM | #16 | |
Luxury at the redline :)
9105
Rep 7,563
You must be doing something wrong.. |
11-12-2019, 08:46 PM | #17 | ||
Rep 348
11-12-2019, 08:47 PM | #18 | |
Rep 348
11-12-2019, 08:50 PM | #19 | |||
9105
Rep 7,563
Under the two folders in FEM folder, if using Bimmercode, change these two parameters below then report back. The rest of settings is just to adjust the sensitivity. |
kianf2264.00 |
11-13-2019, 12:26 PM | #20 | |
Rep 267
11-14-2019, 01:17 PM | #21 | ||||
Rep 348
