      05-31-2017, 12:06 AM   #1
hl0m4n
hl0m4n's Avatar
Arrow ► PC Build: PSU
i am building a pc with the build below but debating if a 650w or 750w is sufficient/overkill.
cpu: i7 7700k
cpu cooling: corsair h115i
gpu: evga 1080 hybrid
ram: 16gb
ssd: x2 500gb
based on various psu calculators, they all estimate 550-600w.
expert thoughts much appreciated, thanks .
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      05-31-2017, 12:41 AM   #2
3rdcoast228i
Drives: 2016 228i Msport
I'm not an expert on PSUs but I've been building PCs since the early 90s and my best advice is don't go cheap.
Getting something overkill is better IMHO
IMHO it's better to not have your PSU working at max capacity.
If you are getting an SLI compatible motherboard it makes even more since to go overkill. You may want to add a second 1080 later.
      05-31-2017, 12:59 AM   #3
kamber
E90
167
Drives: '08 M3
I was in the same boat 1 month ago when I did my build.
PC parts are only getting more and more efficient as time goes on, and if you're not planning on running 2 graphics cards I doubt you would need anything more than a 550W PSU. However, because it's only about $10 or so more per step up from 550 to 650 to 750 to 850, I just went for an 850 so that I'm using half or less of what my PSU is rated for. Remember that it is not only about how much power a PSU is rated for, but the quality and efficiency of said PSU. I went with an EVGA G3 PSU in 850W flavor, but the entire line of PSU's comes extremely well regarded due to being based on SuperFlower's (best in the business as far as PSU oem's go) Leadex II platform.
FYI, if you put all your parts into PC part picker it will tell you a rough estimate of how much draw your system will actually use. See this link to my recent build for an example (look at the top right corner, where it has a little lightening bolt symbol and says "350W"):
https://pcpartpicker.com/list/2rmj9W
      05-31-2017, 06:03 AM   #4
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I'd always default to the larger PSU. You may want a better GPU later and don't want to have to also replace the PSU to support it.
      05-31-2017, 07:47 AM   #5
zx10guy
Drives: 2013 135i
Bigger isn't always necessarily better. I bought a 1100W PSU a while ago thinking that would be the only PSU I would ever need to buy. I didn't pay top dollar but somewhere in the middle. That PSU ended up burning up. I didn't do my due diligence on researching the brand/product and found mixed reviews for it. I was also running dual GPUs in SLI at the time and had problems with the GPUs where both of them failed. Fortunately eVGA replaced them without issue. I always wondered if the PSU had anything to do with the failures.
The comment about the quality and stability of the power is probably the most important in my mind. Here is a website where the reviewers really hammer the PSUs. You should read through the reviews to get an idea of what constitutes a quality PSU.
https://www.hardocp.com/reviews/psu_power_supplies/
      05-31-2017, 12:21 PM   #6
3rdcoast228i
I have been a big fan of PC Power and Cooling PSUs in the past. They used to all be made in the USA but they sold out to OCZ and I really dont know how good they are now since I am still using the PSU I bought from them in 2009.
I do see that they offer a 7 year warranty on SOME of their PSUs
      05-31-2017, 12:22 PM   #7
NickyC
NickyC's Avatar
17485
Just overkill it, PSUs are cheap anyway.
      05-31-2017, 12:26 PM   #8
R3dliner
R3dliner's Avatar
Drives: 18 M3 6MT
Just get the bigger psu its pennies on the dollar. You drive a bmw lol.
Although the 1080 has a lower TDP of 150 watts, I would still get atleast a 750W
      05-31-2017, 01:03 PM   #9
zx10guy
Drives: 2013 135i
I'll mention this again. Just because a PSU is rated to deliver a ton of power doesn't mean it's going to do it reliably. Spend the additional money and make sure you get a quality PSU which can provide stable/clean power. I learned my lesson and won't do it again. Also, instability in power can cause all sorts of weird issues with the operation of the system. Time I would rather spend doing something else more productive over troubleshooting system problems. Just look at any of the power supply reviews at the HardOCP site and you'll know why not all PSUs are created equal even when they have the same power rating.
Soul_Glo13347.00
      05-31-2017, 02:53 PM   #10
Soul_Glo
Soul_Glo's Avatar
Drives: G20
+1 reliable psu first. Personally I think 650 is more than enough
      05-31-2017, 09:43 PM   #11
Xtabi
Xtabi's Avatar
Drives: 2016 M3
I just built a new gaming PC and did a TON of research. It had been about seven years since I built my last one. I was happy to see not much had changed in the fundamentals for picking a PSU.
I highly recommend Toms Hardware and this article. It will have all the info you need.
http://www.tomshardware.com/reviews/...uide,2916.html
On a side note if anyone is in the Quake Champions beta add me! Xtabi
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
      06-01-2017, 01:20 AM   #12
Soul_Glo
Soul_Glo's Avatar
Drives: G20
cpu: i7 7700k
ram: 16gb
ssd: x2 500gb
I have this set up albeit with one 500gb ssd.
I am using a corsair CS series and is more than capable. The top end is RMX / HX and above. They come with 10 year warranty. The lower end have 3-5 years warranty. I think you'd be fine with a VS if you went with the brand. Never had any issues with mine. Heavy use for media editing and leave it on for days on end.
What I love about them is that the top end use genuine Japanese capacitors. Some models have zero rpm at low load. A bit like a class D car amplifier that runs cool.
Corrected to remove the not so good range as per below post.
      06-01-2017, 02:35 AM   #13
Banana Hammock
Beefcake
Banana Hammock's Avatar
3769
Drives: NA
I would stray away from the CX line even if it's from a company like Corsair. It's their bottom of the barrel line and it's not that great.
For the 600-700W sweet spot range, I would recommend the RM or HX series or the AX if you wanna be fancy.
      06-02-2017, 03:59 AM   #14
3rdcoast228i
Yep quality first
Spent almost $500 on my last PSU but it's been cranking out clean power for 8 years. It's been used to overclock from day one with an SLI setup. It's been through 2 upgrade cycles and is about to see an x299 system.
Yes it was costly up front, but I've gotten my money worth.
