      09-26-2021, 11:00 PM   #1
Andy707
Drives: BMW 528i
2010 E60 528i transmission problem
I drive a 2010 e60 528i auto , when ever I put it into gear it says transmission malfunction and makes a bunch of grinding noises what could it be ? And can I put a 328i tranny in
      09-27-2021, 09:56 AM   #2
j30022
Drives: 2000 528i 2008 528xi 2012 X5
Are you able to scan the codes? This is really the first place you need to start. Other than that, you can check the fluid level which will require you to get under the car.
Are you able to shift out of park? Does the car grind in all gears ?
How many miles on the car and any history of maintenance done to the transmission?
      09-30-2021, 09:26 PM   #3
Andy707
Drives: BMW 528i
If I give it a little bit of gas while it’s in park it will go into gear kinda like a clutch , when it did drive it went through the gears but made a grinding noise 130k mikes
      10-06-2021, 01:20 PM   #4
j30022
Don't know about the 328i transmission compatibility. The grinding in all gears could be a torque converter issue, low fluid or severe transmission issues. I would recommend you start with the low cost options, check for any transmission fluid leak. If you see a significant leak, I would pull the pan, replace the mechatronic seals and sleeve then ohms test the solenoids. If you are not mechanically inclined, I would at least drain the transmission fluid and refill to the proper level.
