ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      02-23-2009, 03:26 PM   #23
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
Any decent sized tool kit should have the screwdriver heads for torx screws.
      02-23-2009, 03:26 PM   #24
Burt Reynolds
Burt Reynolds's Avatar
53
Drives: 2007 M Coupe
local hardware store-
edit- just notice I was 3rd in line to answer the question
2007 M Coupe w/NAV/Premium/Extended Leather, Clearbra, DICE, 4.10 BMW Motorsport Polished LSD, Active Autowerke Gen IV Headers, Supersprint Race Exhaust and X-Pipe, ESS Tuned DME, KWV3 Coilovers, Volk RE30, OEM Strut Tower Brace, Short Antenna, JL AMP, JL 10W7, Valentine V1.
      02-23-2009, 04:56 PM   #25
fatmatt0116
Hooligan
fatmatt0116's Avatar
Drives: 2014 Porsche Cayenne Turbo S
disconnecting the battery seems like a pain in the ass since I have limited access to tools here. Can I safely get away with letting the car sit for 30 minutes before taking out the DME?
      02-23-2009, 04:57 PM   #26
fatmatt0116
Hooligan
by the way I just got back from having a zeckhausen CDV installed.....shifts are definitely crisper.
      02-23-2009, 05:06 PM   #27
nmulax
nmulax's Avatar
Didn't disconnect the battery when doing my car.
Got there and popped the hood, locked the car and let the DME cool down and the car go into sleep mode - waited maybe 20 minutes (30 would be safe).
Took out the DME, had the ESS software loaded.
Plugged it all back in, started up the car, and drove home.
      02-23-2009, 05:07 PM   #28
fatmatt0116
Hooligan
thanks
      02-23-2009, 05:37 PM   #29
mpower03
Drives: 08 z4 M Coupe
thats awesome that you didn't have to ship out your DME because your local.
      02-23-2009, 07:26 PM   #30
fatmatt0116
Hooligan
Do any of you use the electronic rev limiter to make sure you dont blow the engine? Where do you keep it set?
      02-24-2009, 08:54 AM   #31
Burt Reynolds
53
I believe standard ESS tune is 8200 ( a slight bump in rev limiter over stock).
      02-24-2009, 09:34 AM   #32
nmulax
nmulax's Avatar
I think stock is set at 7.9k and the ESS software bumps it up to 8.2k
Either way, you're not going to want to constantly bounce off the rev-limiter. As it was explained to me, the extra increase is mostly for dragging or tracking the car - it allows you to hold that gear a bit longer, which could make all the difference.
      02-24-2009, 10:00 AM   #33
fatmatt0116
Hooligan
Ok, I think I may not be understanding one of the features of the onboard computer. There is an RPM adjustment in one of the menus. When you set this, does it not limit how high you can get the RPMs or does it just alert you when you surpass the set value?
Just shipped off the DME, should arrive on Thursday @ 1030a UPS -- Roman, I forgot to indicate on the paperword that I paid for express return shipping. Can you relay this to the ESS guys? thanks
      02-24-2009, 10:15 AM   #34
nmulax
nmulax's Avatar
Hmmm... I didn't drive my M today, so I can't go out and check, but are you sure you're talking about the RPMs and not MPH?
Most newer BMWs (our cars included I think) have the speed warning chime.
This can be set to any speed, and will make an audible chime when you pass that speed. So lets say the speed limit around you is 70mph; you can set it for 78 or so, and that way if you're cruising along and get a bit too throttle happy it'll serve as a gentle reminder to check your speedo.
The M cars also have the variable redline.
Start your car for the first time that day, and you'll notice that revving to 5k or so would put you in the yellow. As everything gets to operating temperatures, the final redline of 8k is shown.
      02-24-2009, 10:30 AM   #35
fatmatt0116
Hooligan
yea but there is another adjustment right below the MPH in the same menu
      02-25-2009, 06:01 PM   #36
mpower03
after coming around to my senses i finally decided on doing thist will do in the next couple of weeks.
      02-25-2009, 06:03 PM   #37
mpower03
oh roman do they work on the DME over the weekend? and how long does it take for them to get it done, like that day?
      02-26-2009, 08:33 AM   #38
Burt Reynolds
53
One other thing I am noticing about the software is that my mpg has gone back up to pre 4.10 days. It is directional at this point b/c I only have 1 tank of gas on the tune, but I will confirm once I get a few more tanks of gas I can measure. If that is true, then 4.10 plus a tune FTW. Also, I am not driving more conservatively...if anything, I am having a little more fun with the tune for right now.
      02-26-2009, 09:26 AM   #39
nmulax
nmulax's Avatar
I don't want to speak for the ESS guys about working weekends (maybe Roman will chime in), but it seems everyone on the forum was without their DME for 2-3 days.
Do it!
      02-26-2009, 09:33 AM   #40
sales@ESSTuning
sales@ESSTuning's Avatar
391
Drives: ESS M3 / M4
work can be done on the weekends but shipping is Mon-Fri
      02-26-2009, 10:51 AM   #41
manjingo
Running Fool
Drives: '06 IB M Coupé
My ECU is done! There were some strange circumstances, but thanks to the fine work of Todd, Asbjorn, and a few others in Germany I'll finally have my ECU back tomorrow.
      02-26-2009, 12:06 PM   #42
sales@ESSTuning
391
Drives: ESS M3 / M4
You got lucky
      02-26-2009, 12:24 PM   #43
Burt Reynolds
53
what happened? sounds like a good one.
      02-26-2009, 02:22 PM   #44
sales@ESSTuning
391
Drives: ESS M3 / M4
I will leave any specific info up to manjingo to tell but I am glad it worked out for him.
zpost
