02-18-2024, 09:50 AM | #1 |
Rep 23
M2 DCT holding on the first gear for too long after startup
Hey guys, I have a question regarding the DCT - I have had my M2 for a little over the year and I have noticed some weird behaviour of the DCT which is more pronounced in winter months.
When I start my car, I have to go out of a garage and then drive up a small hill (approx. 100 metres). If i leave my DCT in drive (no paddle shifts), it changes gears only after reaching approximately 4000 RPMs or reaching the flat surface (and even then it revs high before shifting into second). I guess it is not good for cold engine to rev so high so I usually change it manually. After that first shift, it usually quickly goes into second, third, and fourth and after that it shifts completely normal. Is this behaviour normal? And should I be using manual shifts to override that first shifting procedure? Thanks so much! |
02-21-2024, 07:14 AM | #5 |
Rep 9
It would be nice if the car would automatically rev limit in cold conditions but I believe it's just sensing the throttle required and load on the transmission to get up the hill and gives you more revs. Not knowing that in that moment it should go to 2nd.
spavlas7720.00 |
02-27-2024, 03:28 AM | #7 |
Rep 96
No ... SPORT only selected when the temperature gauge is at OK
Also: From cold start on level ground it hangs on to first, if changed up manually and then back to auto it remains in second (at < 10mph) When hot and going slowly (< 10mph) up our long driveway in COMFORT auto it will drop to first and not accept a manual upshift until a slight increase in speed (~ > 10mph) I accept this as standard practice ...
2017 M2
2000 B5 S4 Avant 1982 Mk1 Golf GTI |
spavlas7720.00 |
03-01-2024, 07:40 PM | #8 |
Rep 431
Drives: F87 M2 DCT, F15 X5
I've noticed this too on the first upshift when the car is cold and your driving uphill. Maybe next time I run into some colleagues who work in the DCT engineering department, Ill ask what they think.
spavlas7720.00 |
03-12-2024, 01:34 PM | #10 |
'20 M2 Comp.
906
Rep 182
Drives: '20 M2 Competition DCT
Mine does the same when I'm driving out of underground parking garage at my apartment. I limit the revs by driving up really slowly. I tend to not manually shift when the DCT is cold because it puts itself into the fastest shifting mode, which doesn't help with the longevity of the transmission.
'20 BSM M2 Competition DCT
IG: @porky_m2c |
spavlas7720.00 |
03-20-2024, 06:52 AM | #11 | |
Rep 431
03-28-2024, 10:50 AM | #12 |
Rep 971
Drives: 2018 M2
All bmw autos do this in my experience. Probably intentionally set that way from factory to warm the transmission fluid to operating temp quicker
Tags |
dct |
