01-28-2015, 04:13 PM | #1 |
New Lifetime Replacement Policy
816
Rep 11,738
:: ECS Tuning :: Introducing ECS Wheel Stud Conversion Kits!!!!!!!!!!!!!!!!!!!!!!!!!!
Why use wheel studs instead of wheel bolts? When removing and installing wheels that utilize the factory wheel bolts the process can be frustrating, holding the wheel up with your legs, lining up the holes, and threading the bolts all at the same time. Wheel studs also allow the use of varying length wheel spacers - a highly convenient feature for those that anticipate using different spacer size setups in the future. Both conical and ball seat lug nuts are available for a maximum of 10mm, 20mm, or 30mm wheel spacer use. Click HERE for your E60 ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E60 ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E60 ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer Click HERE for your E60 ECS 78mm Stud Half Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E60 ECS 63mm Stud Half Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E60 ECS 56mm Stud Half Conversion Kit designed to accommodate up to a 10mm spacer |
01-29-2015, 09:55 AM | #2 |
816
Rep 11,738
Click HERE for your E46 ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E46 ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E46 ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer Click HERE for your E46 ECS 78mm Stud Half Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E46 ECS 63mm Stud Half Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E46 ECS 56mm Stud Half Conversion Kit designed to accommodate up to a 10mm spacer |
01-29-2015, 12:42 PM | #3 |
816
Rep 11,738
01-29-2015, 03:47 PM | #4 |
816
Rep 11,738
Click HERE for your E9X ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E9X ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E9X ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer Click HERE for your E9X ECS 78mm Stud Half Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E9X ECS 63mm Stud Half Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E9X ECS 56mm Stud Half Conversion Kit designed to accommodate up to a 10mm spacer |
01-29-2015, 04:37 PM | #5 |
816
Rep 11,738
Click HERE for your E39 ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E39 ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E39 ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer Click HERE for your E39 ECS 78mm Stud Half Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E39 ECS 63mm Stud Half Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E39 ECS 56mm Stud Half Conversion Kit designed to accommodate up to a 10mm spacer |
01-30-2015, 09:19 AM | #6 |
816
Rep 11,738
01-30-2015, 04:27 PM | #7 |
816
Rep 11,738
Click HERE for your E36 ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E36 ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E36 ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer Click HERE for your E36 ECS 78mm Stud Half Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E36 ECS 63mm Stud Half Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E36 ECS 56mm Stud Half Conversion Kit designed to accommodate up to a 10mm spacer |
02-02-2015, 10:23 AM | #8 |
816
Rep 11,738
02-02-2015, 03:08 PM | #9 |
816
Rep 11,738
02-03-2015, 10:52 AM | #10 |
816
Rep 11,738
02-03-2015, 04:33 PM | #11 |
816
Rep 11,738
02-06-2015, 09:59 AM | #12 |
816
Rep 11,738
02-10-2015, 04:25 PM | #13 |
816
Rep 11,738
Click HERE for your E38 ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E38 ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E38 ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer Click HERE for your E38 ECS 78mm Stud Half Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E38 ECS 63mm Stud Half Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E38 ECS 56mm Stud Half Conversion Kit designed to accommodate up to a 10mm spacer |
03-16-2015, 02:39 PM | #14 |
816
Rep 11,738
Click HERE for your E30 ECS 78mm Stud Complete Conversion Kit designed to accommodate up to a 30mm spacer Click HERE for your E30 ECS 63mm Stud Complete Conversion Kit designed to accommodate up to a 20mm spacer Click HERE for your E30 ECS 56mm Stud Complete Conversion Kit designed to accommodate up to a 10mm spacer |
06-29-2015, 11:02 AM | #15 |
816
Rep 11,738
07-20-2015, 11:21 AM | #16 |
816
Rep 11,738
Click HERE for your E53 X5 Wheel Stud Conversion Kits __________________________________________________ _ Click HERE for your 128i ECS Wheel Stud Conversion Kits __________________________________________________ _ Click HERE for E83 X3 Wheel Stud Conversions |
07-20-2015, 03:03 PM | #17 |
816
Rep 11,738
Click HERE for your E38 Wheel Stud Conversion Kits __________________________________________________ _______________ Click HERE for your 135i ECS Wheel Stud Conversion Kits |
07-21-2015, 11:30 AM | #18 |
816
Rep 11,738
Click HERE for your F30 ECS Wheel Stud Conversions __________________________________________________ _____________________ Click HERE for your E70 ECS Wheel Stud Conversions |
07-22-2015, 10:58 AM | #19 |
816
Rep 11,738
Click HERE for your E46 Non M ECS Stud Conversion Kits ______________________________________________ Click HERE for your E9X ECS Wheel Stud Conversions ______________________________________________ Click HERE for your E46 Non M ECS Stud Conversions |
07-22-2015, 03:38 PM | #20 |
816
Rep 11,738
Click HERE for your E9X Non M ECS Stud Conversions __________________________________________________ _____________________________ __________________________________________________ _____________________________ |
07-24-2015, 12:32 PM | #22 |
816
Rep 11,738
__________________________________________________ ________________________ Click HERE for your E30 ECS Stud Conversions __________________________________________________ _________________________ Click HERE for your E60 ECS Wheel Stud Conversion Kits |
