11-19-2011, 06:53 PM | #1 |
Rep 411
08 5 series shifter assembly replacement
Hi guys,
I just recently had my 5 series taken in for diagnostics. My AS informed me that the automatic shifter threw codes, and the entire shifter assembly needs to be replaced. If it isn't replaced, the car may not be able to come out of gear. Is this a common issue with the 08-10 5 series? If I do go forward with the replacement, the dealer wants $1800. What are my options? Should I get the repair done at an Indy or the dealer? |
11-21-2011, 05:55 PM | #2 |
Rep 357
The electronic shifter was a gremlin since it was introduced in 08. My first 535i was stuck and could not shift to drive. Had to mess with it to get it engaged. Dealer put a new one under warranty. That was back in 08. Just bought a 550i with sport shift, reverse was messed up. Keep throwing codes but had 4 days warranty left so they put a brand new one on.
Anyhow, if i didnt had warranty, a new shifter cost about $230(bmwandmbparts.com). Swap it out is simple just remove center console unplug old and plug in new as they are electronic not the usual stick mount to tranny shifter. Then have someone clear the code,indy shop of course. Less than 500 bucks. More less if you diy. Funny how bmw stealership thinks whoever drives a bmw have tons of money. |
11-21-2011, 07:04 PM | #3 | |
Rep 411
11-22-2011, 12:04 AM | #4 |
Rep 357
No problem. I dont know if this helps but heres what my reciept says.
:Customer states when put in reverse shows gear lever malfunction on CID Cause:Gear selector switch (lever) Permanent malfunction 0000006 performing vehicle test (with vehicle diagnosis system) 6140WPB94 1 61-31-9-208-271 Selector Lever Handle: 61309931TZ Removing and installing gear selector 6140WPB94 Note(on receipt):Performed replacement of the selector level handle/switch and recheck function. Check control warning is not longer present when shifted. Cleared fault memory. So basically, they just replaced and clear fault code. |
