BMW M2 Forum > BMW M2 Competition Model > Recommended weight reduction for M2 Competition
      05-04-2018, 04:50 PM   #23
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
Originally Posted by Bluenose-2er View Post
How about switching out the S55 for an N55?
Seriously though... I think the general expectation is that the weight gain is mostly in the front because of the heavier block, heavier cooling system, etc of the S55 and the fact that (the engine) is the only really significant change... as well as the associated exhaust, of course.
Lighter manual seats are a need for both the M2 and M2C.
He's right. Stuff an N55 under the hood.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      05-04-2018, 05:15 PM   #24
M3_WC
Drives: M3
Then you have an inferior front mount air to air cooling. No thanks the additional equipment is a huge upgrade.
      05-04-2018, 05:21 PM   #25
M3_WC
Drives: M3
Originally Posted by cntzl View Post
Even MPE saves 26lbs over stock exhaust on M3/M4 so I'm hopeful as well.
Yeah, also the MPE retains the secondary cats and is still dual path. The ActiveAutowerkes midpipe posted earlier in this thread is single path and deletes secondary cats(easily another 10lbs plus savings).
http://f80.bimmerpost.com/forums/sho....php?t=1092134
OEM Exhaust Weights
Full System: 69lbs
M-Performance Exhaust Weights
M-Performance Muffler: 14.20lb
M-Performance Midpipe: 22.25lbs
M-Performance Carbon Fibre Tips (ea): 1.0lb (x4)
M-Performance Hardware (ea): 2.35lb
Combined Weight: 42.80lbs.
Important: Note that the M-Performance is a "Cut and Clamp" style, retaining secondary catalytic converters while keeping emissions compliant, which on the downside, retains a slight bit more overall weight when clamped to the remaining part of the OEM system. Unfortunately, we were unable to get a total weight before installation .
Just as a comparison:
Akrapovic Exhaust Weights
Slip-On Section/Silencer: 29.5lbs
Connecting Pipe: 14.0lbs
Combined Weight: 43.5lbs (25.5lb weight savings over OEM)
      05-04-2018, 05:34 PM   #26
No Boost
No Boost's Avatar
Agreed. It was a tongue in cheek response. Happy hour had me by the balls.
      05-04-2018, 05:43 PM   #27
M3_WC
Drives: M3
Has anyone weighed the stock N55 M2 exhaust(including midpipe)?
      05-04-2018, 10:27 PM   #28
mtoosexy
mtoosexy's Avatar
730
Drives: It like I stole It.
HS is definitely a lighter color than MG.
I would take mineral grey over HS even if mineral grey were 155 lbs heavier!!!!!
P car or AND M2>
Yiruna393.50
      05-04-2018, 10:32 PM   #29
mtoosexy
mtoosexy's Avatar
730
Another way to save weight is to only fill you tank with up to 2 gallons of gas.
13.7 gallons of gas weighs @ 84 lbs
2 gallons of gas weighs @ 12.4 lbs
weight savings = 71.6 lbs
P car or AND M2>
      05-04-2018, 11:36 PM   #30
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
How much weight would it really take to "feel" the difference? On the streets? On the track?
I would think it would be a lot (like more than 200 pounds)...but I honestly have no idea.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      05-05-2018, 12:32 AM   #31
M3_WC
Drives: M3
Is there anymore info about the particulate filter BMW is beginning to put on petrol cars. The M4 will get it soon. M2C will have the filter from the beginning. I know the BMW diesel particulate filters are quite large piece and heavy. I also seen a couple people on 2ertalk say the US bound M2C won't be fitted with a particulate filter and that is the true reason the first build allocations are going to the US. Not because they want to release the car at the same time in all countries.
F30.M13.00
      05-05-2018, 01:25 AM   #32
Guydj1
Guydj1's Avatar
51
Drives: BMW M2 LBB
Surprised lots of talk on weight reduction when no one has driven it yet and are prepared to spend hundreds if not thousands putting it on a diet. The extra 55kg is similar weight to my daughter sat in the passenger seat.....thought it best not to use the wife as an example I don’t notice a big difference. I can’t see M division taking a step back when it comes to handling. Performance in a straight line we all know it will be quicker than the current M2 in particular 100kph to 200kph but by how much
      05-05-2018, 08:19 AM   #33
Karmic Man
Karmic Man's Avatar
Australia
1996
Drives: M2C
Lots of carbon options from M to save weight now...lol
      05-05-2018, 09:10 AM   #34
MR.
MR.'s Avatar
Drives: BMW M2 CSL Turbomeister
BMW released their dietary program today... It is called BMW M Performance.
MR
      05-05-2018, 11:12 AM   #35
Artemis
Artemis's Avatar
29443
Drives: BMW M2 Competition
Another way to save weight is to not step into the car.
///M is art Artemis
      05-05-2018, 11:47 AM   #36
MR.
MR.'s Avatar
Make it a single seater... Problem solved.
MR
      05-05-2018, 01:37 PM   #37
zenmaster
Drives: '17 M2
The OP is about using the M2C specifically on the race track. Regardless of the M2C's stock capabilities, it or any car will perform a lot better when lighter. I think many here can attest that it's also simply more fun to drive a lighter car. Having daily driven an older 2850lb 380hp 2-seater car for years, it feels that we've gone backwards. And of course, lighter cars than that are even more raw, road-connected and fun to drive. Over the years, safety and comfort won out apparently.
I can't see significant factory-made weight losses in the near term until CLAR makes its way down into the 2-series chassis. A more purpose-built CSL may be offered at that point. They may look nice, but even if you got them all installed, the M-performance carbon parts really aren't going to make a big difference in weight - probably about the same difference as BMW removing some of the sound deadening material from the standard 2-series.
      05-05-2018, 02:23 PM   #38
Artemis
Artemis's Avatar
29443
MR
Very likely a lot of the current M2 owners opt for *ultimate* weight saving on the M2 Competition: not buying the M2 Competition.
///M is art Artemis
BOhio175.50
      05-05-2018, 03:08 PM   #39
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
MR
They didn't opt for anything. That was their only option. Curious how many of the current M2 owners would have "opt for" the base M2 if these two had been offered together.
      05-05-2018, 04:11 PM   #40
Artemis
Artemis's Avatar
29443
It's not about the past. It's about now: if you got an M2 for the moment, keeping it or do you consider trading it in for an M2 Competition ?
It seems that most over here prefer keeping the ship at bay (and of course finance and timing are important parts of the equation): see here ("Those already having the M2: trading in for the M2 Competition ?").
///M is art Artemis
      05-05-2018, 04:17 PM   #41
CommitConfirm
Drives: The Bus
Driver loose some weight
      05-05-2018, 04:45 PM   #42
Guydj1
Guydj1's Avatar
51
Drives: BMW M2 LBB
I don’t disagree a diet gains you performance. If it’s to be used as a track car part of the time, remove the rear seat, passenger seat, carpets, door cards, and drive it to the track cost free option, you could always refit. my thinking is when you don’t remove items but exchange for light weight components it will cost a significant amount of money. I’m sure there is no right or wrong light weight components vs component removal
      05-05-2018, 04:49 PM   #43
M-Pilot
M-Pilot's Avatar
When you said "opting for not buying the M2C", it sounded more like (to me) as if they had an opportunity to make a choice between these two cars when they were making their car buying decisions but I see your point now. I think many people who are planning to keep their M2s are doing so not because M2C weighs more or sounds worse but because they don't want to take the financial hit, which is quite understandable. If I already had the base M2, not sure whether I would upgrade to M2C or not but I'd be very tempted.
Artemis29443.00
      05-05-2018, 06:05 PM   #44
Artemis
Artemis's Avatar
29443
I agree.
Let's face it, an M2 trade-in for an M2 Competition right now, would be more emotional-driven decision-making, than rational-driven decision-making. Most will take a financial hit on the existing car and risk to get sucked deep into the options and M Performance Parts wormhole for the new car. Allow yourself to give it some thought, sleep over it and consider the things that matter most for you (the balance of interests, trade-offs, equation, etc.). Yes, it's all pretty personal. And what about the emotions surfacing when a nicely kitted out M2 Competition passes by ? Well, that's one of the trade-offs for the more rational-driven decision to keep the current car.
Many moons ago, when I pitched the 'M2 to M2C' trade-in idea to my wife, she asked me straightaway: "Wait a sec, is there anything wrong with your car ?". Kinda says it all (also about my wife).
///M is art Artemis
SW192457.50
M-Pilot4859.00
ChrisK4450.00
Poochie9104.50
m2
