      12-30-2024, 01:39 AM   #1
brgolf
Drives: 2009 528i E60
Angry Mystery Misfire and Stalling at idle N52
Throwing multiple codes and can’t figure out what is the problem. Car misfires on all cylinders over 3500 rpm (have to shutoff and clear codes then drives fine under 3500rpm) Car will stall at idle when warm, will never stall while driving though.
REPLACED ALREADY
-Coils
-Plugs
-Camshaft sensors
-Crank Sensor
-Fuel Pump and filter
-Have cleaned vanos
-Eccentric Shaft sensor not replaced but is clean no oil in sensor List of codes in the screenshot
      01-18-2025, 09:25 AM   #2
633csi
Drives: 2006 e61
How often do you change your engine oil? And what brand oil/type do you use? Sounds random? The Vanos needs good oil pressure and clean oil to function properly. Just a hunch.
brgolf0.00
      02-06-2025, 04:35 PM   #3
Cuskolini57
Drives: E60
My friend had a problem similar to yours after replacing timing chain, car was not timed properly
      02-06-2025, 05:02 PM   #4
brgolf
So i some how overlooked that i had plugged the Intake Vanos connector into the exhaust Solinoid and vice versa , car seems to run better , havnt driven it much since though
      02-06-2025, 05:03 PM   #5
brgolf
Pretty sure this was the reason for the car stalling at idle and misfiring at over 3500 rpm , im getting it reinsured today so ill keep yall updated
