01-07-2018, 01:45 PM | #1 |
Rep 7
hearing water moving back and forward F83
Hi all,
Im new here, dont know any F83 owner had this problem! While im driving slowly and brake i heard near side rear sounds water moving backward n forward, like bottle of the water on the back seat. |
01-07-2018, 04:34 PM | #2 |
Rep 2,379
Isn't that just fuel in the tank? My F20 M135i has done the same thing since new.
01-08-2018, 01:16 AM | #3 | |
Rep 701
Run the tank down and see if its still doing it and then repeat test when full? Also, have you checked under the seat to make sure a passenger hasn't actually left a bottle in the back?
Wo-Wo Detailing Accessories
www.wo-wo.co.uk |
01-23-2018, 07:50 AM | #5 |
Rep 7
Hi guys...at the end i took my F83 to dealer for checking you can see how much water came out.....
https://video.citnow.com/vthq-0S14Hj |
as7920600.00 |
01-23-2018, 11:11 AM | #7 |
Rep 7
I have no idea.....the dealer said to me they want to keep my car overnight to investigate the leaking...it less than 2yrs old only.... i hope this under warranty....no need to pay anything.
01-23-2018, 11:17 AM | #8 | ||
Rep 3,574
I've never heard gas sloshing in any car, ever. |
01-23-2018, 01:50 PM | #9 | |
Rep 701
www.wo-wo.co.uk |
01-23-2018, 01:51 PM | #10 |
Rep 701
Like a bat!!
www.wo-wo.co.uk |
Killed by Death12657.00 |
01-23-2018, 02:03 PM | #11 | |
Barge driver
8658
Rep 12,425
Warranty should be fine you've got 3 years from new.
730d/Z4C
02-02-2018, 03:19 PM | #12 |
Rep 35
Hey bud,
I had this issue twice on my M4 cab (first the drivers side and then passenger). When It rains the water should travel down the inside of the rear quarter pannel (i.e. where your rear windows are) and the water then comes out of the underside via a drain. When the drain gets blocked with debris the water sits on the inside. The fix was to unblock the drain and from what I recall they made the hole a bit larger. Never had an issue again. Second time it was the other side. Hope that helps. |
02-27-2024, 05:28 PM | #13 |
Rep 1,172
Hey all, usually in the garage but had the f83 in the rain and have a bunch of water stuck in there. Has anyone done a diy for this. Bmw told me they want $400 just to drain the water... its a 2015 so no warranty
03-01-2024, 03:34 PM | #14 |
Rep 132
F80 M3 Comp in Sakhir Orange
