07-01-2010, 06:50 PM | #1 |
Rep 1,435
Creatine... To load, or not to load..
Can some of you guys, who are a lot better informed than I am, give me your opinions on whether I should do a loading phase?
I took creatine about 5 years ago.. I believe I did a loading phase back then. Is it extremely important? Can I just do a pre and post workout regiment? |
07-01-2010, 09:43 PM | #2 |
Rep 729
Drives: 2007 E92 335i
I'm doing a 20g/day loading phase, but have read that it really isn't necessary to achieve saturation in the muscles. 20g/day for a week isn't harmful, so I don't see what the negatives would be.
2013 BMW Z4 sDrive35i|DCT|M-Sport|iDrive|Premium Sound|Heated Seats|Comfort Access|PDC|Deep Sea Blue|Cream
[At the port of exit awaiting a shipping vessel since 8/17/12] |
07-01-2010, 11:38 PM | #3 |
Rep 533
I've read and heard conflicting things about creatine use, as well as the actual benefits of taking it. If you do take, it, at least make sure to drink plenty of water to lessen the strain on the kidneys.
COH4777
2007 335i Coupe - Jet Black / Coral Red / Aluminum Trim / 6MT / Sport / Premium / CA / Navi / iPod + USB |
07-02-2010, 10:30 PM | #6 |
Rep 1,352
07-02-2010, 10:41 PM | #8 |
Rep 1,512
i wouldnt load, your only working out 3 days a week. You cant even cover all body parts in 3 days. Why do you even want to take creatine in the first place?
2002 AW/IR : Sold
2004 AW/BLK : Sold 2009 AW/FR : Sold 2015 AW/SO |
07-03-2010, 07:01 AM | #9 |
Rep 470
Do not load, it's just not necessary.
2012 Blue Pearl GT-R
1068whp & 906wtq on E85 / 60 - 130 MPH in 3.8 secs 2009 BMW M3 ESS Supercharged / Nitrous - 10.87 @ 131 MPH / 60 - 130 MPH in 6.23 secs |
07-06-2010, 09:31 AM | #10 | |
Rep 1,435
Bi + back Legs + Shoulders Everyday in between is push ups and some cardio. I am trying to put on weight/tighten up mid section. I have already put on like 20 pounds in last 4-5 months. Kinda hit a wall at 160-63. I don't have time to work out 5 days a week otherwise I would. I drink a ton of water already. So I should use it pre and post work out and leave it at that? |
07-08-2010, 03:24 PM | #11 |
Rep 1,512
I would just take it post workout. If you looking for something that's good to take before you lift that has creatine in it try jack3d by usp labs. Great product and it's cheap. If you have more time I would try splitting up your leg and shoulders into two seperate days. Legs is big muscle group and I dunno how you could even focus on a good shoulder workout after legs but to each his own.
2002 AW/IR : Sold
07-08-2010, 03:35 PM | #12 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
Listen it all depends on the product, if it is an ethyl ester product there is no need to load as it is very soluble, this helps with cramping, dehydration, and advanced absorption.
Ethyl Ester makes the Creatine more lipid soluble meaning it is an advanced formula that helps the creatine travel through the cell membranes more rapidly, where as your typical monohydrate does the exact opposite. If you are running a typical monohydrate, more than likely you will need to load, however, you better be taking in mass amounts of water to flush your kidneys as you will feel it a few weeks in. You may experience some cramping in your lower back as your kidneys can not flush that amount of creatine on it's own.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
07-08-2010, 03:42 PM | #13 |
Sensei
52
Rep 1,054
First of all, this thread is full of useless advice for you. You didn't specify your height or your BF%
You CAN effectively hit all body parts in a 3 day split so that other guys advice above is false. But, I would definitely change your routine because at 160 pounds, you are definitely still a beginner and shouldn’t be doing that split yet. These splits do work… But it isn’t the best solution for you at this point since you’ll be missing out on tons of size due to your lack of volume vs. recovery. As for supplements. No to loading on creatine. Yes to taking creatine post-workout along with your Whey or isolate protein. First, you need to calculate your 10 rep max for all compound movements for: Deep Squats (Ass below parallel) Flat bench press Bent Over Rows Military Press Stiff Legged Dead Lifts Then, we can create a routine around those numbers. Your 10RM should be about 70% of your 1RM If you’re looking to increase size, you need to increase strength. This is why we're working off you're 10RM. The amount of weight you gain is almost entirely dependent upon your caloric intake. At 160 pounds, your caloric maintenance levels are around 2400 calories and around 3200 calories if you need to put on some size. Focus on a % split of 40/40/20 for carbs/proteins/fats As far as slimming down your waist/abs – I would suggest high intensity interval training for no more than 2 hours a week. HIIT is more effective than aerobic level cardio at 70%MHR IF you are trying to gain muscle (lifting weights). Otherwise, cardio for 20-30 min at 70-80%MHR will be perfect for losing body fat. Remember to keep your calories clean.
07-08-2010, 03:54 PM | #14 | |
505
Rep 35,580
Drives: JB 33ZERO
I will agree with you on this tho, if you are unsure about supplements, dont take them! Plain and simple! I know too many people that have there libido and testosterone levels all messed up from not researching stuff before you take it! Creatine is pretty safe, but anything past this and you better read up!
07-08-2010, 04:40 PM | #15 |
Sensei
52
Rep 1,054
^^ haha i know.. but then i read he wants to add some size because he's been stuck around 160 lbs. Figured the info might be beneficial to him, that's all
Like you said, research is key. All you really need is Protein and Multi Vitamins really. Throw in some fish oil pills or flax seed if you want to get your Omega3's in there !
07-10-2010, 09:18 AM | #16 |
Rep 2,229
Drives: e92 M3 6MT/Audi A4 Prestige
i would not use creatine at all, i used it in the past but its not healthy to use a straight creatine supplement, now i use just a pre workout which has a small amount of creatine in it but not much(jack 3d) and protein after workouts twice a day on heavy days and once on non lifting days, to gain mass protein and more calories in your diet is the answer, just make sure they are healthy calories or else you will gain the wrong kind of mass lol
SSII E92 M3 6MT/Audi A4 Prestige/2016 Tundra Limited Crewmax
Previous: 07 BMW x5 4.8i|06 BMW 330i Sport|2015 Jeep Wrangler Sahara Ultd|2012 Mercedes C250 Sport |
07-10-2010, 12:37 PM | #17 | |
Rep 729
That concerns me...
07-10-2010, 04:00 PM | #18 | |
Rep 1,512
2002 AW/IR : Sold
07-25-2010, 11:50 PM | #19 |
Rep 1,124
08-09-2010, 04:49 AM | #20 | |
Rep 964
My workout week is something like: Monday: Chest (push) Tuesday: Back (pull) Wednesday: Triceps (push) Thursday: Biceps (pull) Friday: Legs (push) Saturday: Shoulders + abs Sunday: Rest Now onto the Creatine topic: I've only started using it 4 weeks ago. I went through with the loading phase 20g per day @ 4 x 5g split up. 5g in the morning after breakfast, 5g after lunch (especially after my carb intake), 5g immediately after workout (I take my creatine jug with me to the gym and shake it up within 5 minutes of exertion lol... a little excessive, I know) and my last 5g was at night after my dinner. I did this for 1 week. After (the past 3 weeks), I've been on 10g a day (5g after lunch and 5g immediately after workout). I've got another week left in my intake cycle before I go off for the next 7 weeks. I noticed that I had more gas than normal and that I was thirsty as hell. I went from drinking normally about 2 litres of water a day to AT LEAST 4 litres... I pee a lot and its annoying. On the bright side, I've already broken past my plateaus and weight the same I did 5 weeks ago, but I look a lot bigger. Otherwise, it's been the best supplement I've taken by far.
