02-25-2009, 01:42 PM | #1 |
Rep 5,623
PS3 Wi-Fi F***ing Blows
spent like all day trying to get the ps3 connected and no luck, and when i search hell i wasn't the only one. im trying to get it up with linksys and i officially gave up.
once i try the router has to be reset so after numerous tries and resets screw it. if i stick a wifi usb key will it work? http://catalog.belkin.com/IWCatProdu...duct_Id=299142
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
02-25-2009, 01:47 PM | #2 |
Rep 4,388
Drives: 2022 F97 X3M Comp LCI
Mine's been working for years now. Sorry to hear about your troubles. My PS3 has been reliable ever since I got it (60GB).
Can't help you there.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
02-25-2009, 02:02 PM | #4 |
Rep 586
I've had my PS3 for about 2 years now, and been using the wi-fi on it since day one. Its performed pretty flawlessly. Its probably either a problem with the settings your attempting to use on the PS3 or the router.
02-25-2009, 04:07 PM | #5 |
Back in the f80
55
Rep 815
The original PS3's (60gb) version came with a better wi-fi system including the reverse play for ps2/ps1's games. Unfortunately they cut back on all of these extra amenities to make the Ps3 more cost efficient which in my opinion is a crock of sh*t.
2003 SS S2000
2016 MW F80 2018 BMW X3 X-Drive |
02-25-2009, 04:09 PM | #6 |
Rep 214
I had a similar problem with my linksys router. If you have alot of traffic such as online gaming and other computers downloading, mine used to freeze and disconnect everything. I found that there was an update the firmware on the router and this fixed my problem.
02-25-2009, 04:20 PM | #7 |
Rep 2,312
Drives: 2016 LB M2 / 2020 X5 40i
i have the 40g ps3 and i have no problem with the wifi
02-25-2009, 04:46 PM | #8 |
you know he kills little girls like you
388
Rep 892
Try using a different router, or set up a wireless ethernet bridge. E.g. I've got a machine I run FreeBSD on that has a built in ralink wireless 802.11b/g USB card. The signal the card tramsits is weak. The main router in my home is an Airport Extreme, however since the FreeBSD box isn't in the same room with the router, I bought an Airport Express to act as a wireless ethernet bridge. The Airport Express connects to the Airport Extreme (main router), and the FreeBSD box connects to the Airport Express via UTP (ethernet cable). The Airport Express is about the size and shape of a Mac power unit and plugs directly into the wall. It's draft 2.0 802.11n compliant as well, which means you can achieve speeds of up to ~300Mb/s.
Linksys makes a similar device, but it's (*gasp*) more expensive than the Apple product in this case. |
02-25-2009, 05:29 PM | #9 |
Rep 616
If your linksys is flashable I would suggest that. Check out dd-wrt.com. The firmware is way more customizable than the linksys interface.
No need to change brands, I have a couple linksys routers and they both work fine with my 40gb ps3. The wifi signal from the PS3 is slow, however. I eventually bagged wifi directly from my gaming systems and setup a bridge in my TV room using an old router. Works much faster now. |
02-25-2009, 05:44 PM | #10 |
heel toe
27
Rep 182
i have a 40gb ps3 and my wifi blows also. I tried numerous times to get it to connect. Got it to connect once and it failed after that. I gave up and just hard wired it to avoid all the bs.
02-25-2009, 05:47 PM | #11 |
Rep 2,210
Wi-Fi on my ps3 rocks. Hooked up in a matter of minutes and starts streaming huge movies/tv shows in a matter of seconds via Tversity loaded on my PC.
________ medical marijuana states ________ Vaporite solo Last edited by stimpy; 02-18-2011 at 05:00 AM.. |
02-25-2009, 07:03 PM | #12 |
Rep 586
The wifi on the ps3 is fine, its most likely your router. My roommate and I play COD online all the time on 2 ps3's right next to each, and our signal/connection is never a problem. The only time it glitches out is due to another host having poor connection.
02-26-2009, 12:45 AM | #13 |
Da Kid
121
Rep 4,576
mine works perfect!
MODS: OEM Front Splitter | ACS Roof Spoiler | OEM Trunk Spoiler | Matt Black Front Grill | Black Shadowline Window Trim | Painted Front Lower Rod | Blacklines | JDM Yellow Fogs | Custom Silver CF Headlights with LUX 4.0 | Eisenhaus Sports Exhaust |
02-26-2009, 05:59 PM | #14 |
Rep 5,623
finally got the thing to work. updated the firmware, and reset it (forgot the reset part) and voila. jebus got the spec III update now
03-03-2009, 09:08 AM | #15 |
Seaman
69
Rep 518
