01-13-2012, 05:36 PM | #1 |
Rep 140
Ignition Coil Failure
Started her up this morning. Rough engine with vibrations evident in the cabin. Engine malfunction light on. Drove to dealer at 55-60mph on highway with no trouble. Dealer put me in a loaner asap (kudos to BMW of Darien) and diagnosed an ignition coil failure. 8.5k miles. A little miffed...what have others experienced?
Current: 13 X5 Diesel, 991 Carrera S 50th Anniversary Edition Gone: 11 E90 M3 ZCP, 07 328i ZSP, 05 330i ZHP, 04 996 GT3, 02 525iA, 02 996 C2, 01 Boxster S |
01-13-2012, 06:24 PM | #2 |
Rep 146
i have a similar situation but not with the ignition coil, dealer said vacuum pump problem... i hear a very frequent loud buzzing noise coming near the brake reservoir.
anyone can help? |
01-13-2012, 11:07 PM | #4 | |
Rep 220
see thread: http://www.m3post.com/forums/showthread.php?t=630110aa Anyway they thought it was the idle air valve, after replacing that it didn't solve the problem, after talking to BMW NA they decided it was an ignition coil issue, which I am now getting replaced. Have been waiting for the past week for the parts to come in from Germany. I only had 3202 miles on my car at the time of the malfunction. Glad to know I'm not the only one. Have been driving around in a 328i loaner, but man I miss my m3.
"This is like having a house-cat that’s a bengal tiger." - Todd Deeken, everydaydriver.com, on owning an e90 m3.
01-14-2012, 11:30 AM | #6 |
Rep 8,077
Drives: 11 E90 M3 Individual
It happens, just comes with having a car that uses separate coil packs instead of a distributor.. I had a 5k mile old coil pack blow at the track in the morning. Lost a whole day.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue Last edited by bigjae1976; 01-14-2012 at 02:01 PM.. |
01-14-2012, 01:23 PM | #7 |
Rep 843
Coming from the VW world, I'm accustomed to seeing coil pack failures. But still, it's more an annoyance than anything else, forcing you to have to go to the dealership, likely twice, once to drop the car off, and on another day to pick her up.
01-14-2012, 04:11 PM | #8 |
Rep 651
Drives: 2008 Melbourne Red M3 Coupe
In speaking with my SA (whom I've worked with for over 10 years) BMW has not had the repeat coil failures in the e9x that plagued the e46.
Chief PS - I went through 3 sets of coils in my e46 M3. |
01-15-2012, 10:32 AM | #9 |
Rep 220
My SA was stumped when I brought my car in, it was only when they consulted with BMWNA that they diagnosed the ignition coils. The blamed it initially on the idle air circuit, which I know was an issue on earlier year e9x m3s.
04-16-2015, 10:01 AM | #10 |
MMA Changed My Life!
319
Rep 6,629
Drives: e92 m3 & f30 328i
great read I wonder if anyone else has had this failure recently.
04-16-2015, 06:34 PM | #11 |
Rep 96
I did at 29,000 miles. Replaced three
99 Vette Vert - Rocket- sold / 10 MDX - Wide DD sold / 15 Fusion Hybrid - Company Car (surprisingly good)/ 15 Tahoe LTZ - Kid Hauler / 11 E93 - My White Beast aka The Mistress
04-16-2015, 06:54 PM | #12 |
Rep 6,733
I wonder what specific DME error codes were spit out that led them to diagnose the idle air circuit vs the ignition coil/s?
It might help others on this forum as to not spend money on items that won't help fix the issue. |
04-16-2015, 07:58 PM | #13 | |
Rep 581
04-16-2015, 07:59 PM | #14 | |
Rep 581
07-15-2018, 02:35 PM | #15 | |
Rep 163
I know that this is a three year old thread but since I am facing a similar issue, I didn't want to create a new thread and instead use this. Quick background: Mine is a 2011 E90 I purchased recently from a fellow member; car has 43k miles on it and I am the second owner. Weekend car. Car is perfect but going by the suggested old school maintenance, I had my friend (an ex-master tech) replace at his shop the spark plugs using NGK. This was two weekends back. After replacing the sparks, he checked the codes and found an error code on coil # 3. After swapping it with other coils and rechecking the codes, he confirmed that it was indeed a faulty coil and we replaced it with an OEM coil. All was clear, and car seemed fine for last two weeks. During the last few rides this week, I noticed a distinct but extremely brief loss of power when changing between 2, 3 and 4, and I assumed that I was doing a sloppy job when disengaging the clutch. Plus, I wasn’t sure if this was due to the battery which is still original. Last evening on the highway, I got the engine malfunction message and the 'service engine' light. Car now has rough idle and thanks to guidance my buddies here - BOOF and Derbo -, I took the car immediately to Autozone to read the codes. (yeah, I am going buy a tool soon.) Autozone's tool indicated two error codes P138B and P0357. BOOF checked those for me and disclosed that it is ignition coili # 7 and also oxygen sensor. Would love to hear some feedback/guidance from other members on the following: 1. If you chanaged your coil, may I know the year of your car and the approximate mileage you changed it please? I know that a good % of you are still on the original coils but still curious to get details from those who changed. 2. If you changed, did you change all 8 or only 1 at a time? 3. OEM or any other manufacturer you would recommend? I cringed on paying $135 at the dealer, and found that OEMs cost about $91 online. Prefer OEMs but if I have to replace all 7, better to get your opinions. 4. Could the second coil's (# 7) failure be due to my tech friend not doing the job properly two weeks back when he changed the spark plugs? I ask because it's been < 150 miles with the new sparks and one new coil (#3); surprised to see that # 7 possibly went bad so soon even though it appears that many earlier model M3s with higher mileage are yet to change even one. Hence these queries to see if it could be a human error or my bad luck with the coils. Thanks! Last edited by BimmerRules!; 07-15-2018 at 07:12 PM.. |
DrFerry6734.50 |
07-15-2018, 11:29 PM | #16 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
I've never heard of coil pack issues plaguing BMW's. My 335 was on originals up till 220,00. I'm on my originals in my M3 with 160,000. Are you guys changing your plugs and batteries when you should? I do plugs every 50,000 and battery every 4 years. No issues with either BMW knock on wood.
07-16-2018, 09:07 AM | #17 | |
Rep 163
Mine has 43k miles (2011 make) and since it is still on the originals, I first thought of doing the sparks and then the battery. The coil error messages started after the spark plugs swap. FYI that I had purchased the NGKs from FCP Euro using the OE 12120032273 #. Their order also confirms that they are the same G Power LKR8AP spark plugs installed in the factory and sold as replacement parts by BMW. |
07-16-2018, 09:24 AM | #18 |
Rep 1,930
These cars are known to have coil failures after a spark plug change. 1/3 cars I did the change on had 1 coil malfunction. Typical misfire in cyl x. Swapped coils around and the misfire jumped to the other cyl.
BimmerRules!110.00 DrFerry6734.50 |
07-16-2018, 09:52 AM | #19 | ||
Lord Scrip
1823
Rep 3,018
-Did you vacuumed out the plug area before unscrewing? -How did the coil pack look coloring wise, (black or starting to grey)?
07-16-2018, 10:15 AM | #20 | |
Rep 163
Glad that I am not alone. follow-up question: did you change only that coil or all 8 when that occurred? The master-tech buddy of mine said that he and dealer often see the failures start hitting other coils and hence recommend replacing all of them. (He is a good friend and I trust him btw.) I honestly don't mind swapping all 8 but the OEMs are $90 a piece online and given the beauty of these cars, I hesitate to buy other brands that are available anywhere from $40 to $80 per coil (from FCP and ECS, both reputable sites). Thanks again, |
07-16-2018, 10:18 AM | #21 | |
Rep 1,930
On my car I've been running 14k miles since a plug change at 30k with no issues. |
07-16-2018, 10:21 AM | #22 | |
Rep 163
1. My master did not gap the plugs but both he and FCP Euro informed that we need not as its been pre-gapped for the 2011 M3. I am all for checking it again but not sure if one needs any special equipment. Do you know? Or, if OEM plugs will be sure to be pre-gapped, I can buy those instead and replace all the sparks again. That could save the trouble of the coils going bad. 2. I don't think he vacummed the plug area, but will request him to do it this time when he changes the other coil. 3. Turning greyish if I remember right but I didn't look @ it close. Will check tonight and keep you posted. Please let me know your thoughts on point 1 as I am about to place the order thru FCP Euro (delivery by Wed, and I can drop the car off with my master tech buddy on Thur so that he does the work patiently on Friday.) Thanks a lot!! |
