10-23-2017, 09:37 PM | #1 |
Rep 6,068
Upgrading Mac with SSD
How many of you have done this upgrade? This has made my computer 10 times faster at least. It is as fast as the new machines in the Apple store, maybe faster. I'm afraid if I get a touch bar mac it might actually be slower.
10-23-2017, 09:42 PM | #2 |
Primo Generalissimo
4701
Rep 4,043
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Done it to an older MacBook and an iMac. Definitely helped extend the life of both.
10-24-2017, 07:38 AM | #6 |
Rep 7,457
Put a 500GB SSD in mine and moved the original 500GB spinning drive to the DVD bay, so now I have 1TB of space. Never missed the DVD drive. It boots to the login screen in about 20 seconds.
We've upgraded most of the lab PCs at the school like this. Works wonders.
10-24-2017, 08:53 AM | #7 |
Rep 6,068
Never thought about moving the existing drive to the dvd bay. I did think about putting another ssd in the dvd bay and doing a striped RAID between the two drives for even better performance boost but that's an idea too.
10-24-2017, 09:30 AM | #8 |
Rep 7,457
You can't put an SSD in the DVD bay. Something about the connection to the motherboard. Unless some company has come out with a new kit in the couple of years since I made the move. But at that time, the DVD bay kits wouldn't support SSDs.
10-24-2017, 09:50 AM | #9 |
Rep 6,068
Yeah it depends on the motherboard if the dvd drive still uses the older ide connector. On my MacBook it uses the newer connector so I can put an ssd in there. My computer is super fast as it is though so I'll leave the DVD burner for now. I'm running high Sierra without any issues but if the next version is slower I may do the raid drives.
10-24-2017, 10:30 AM | #11 |
Rep 6,068
There was a video on unbox therapy showing the SDD Raid upgrade involving removing the dvd drive so I know it's possible. It can be done with or without an adapter to the connector depending on what you have. Though the older connector won't yield as much of a speed improvement.
10-24-2017, 10:36 AM | #12 | |
Rep 7,457
https://eshop.macsales.com/item/OWC/DDAMBS0GB/
10-24-2017, 10:55 AM | #13 | |
Rep 6,068
10-24-2017, 10:59 AM | #14 |
Rep 940
Drives: 2022 X3M
3yr iMac 27 just got a SSD drive and it's incredible how much faster it is.
SAMSUNG 850 EVO 2.5" 250GB SATA III 3D NAND Internal Solid State Drive (SSD) MZ-75E250B/AM and freakin' cheap! https://www.newegg.com/Product/Produ...3yRBLyPn-8g%3D
2022 X3M
2017 Cayman (Ret) 2019 X3 M40i (Ret.) 2015 F82 ///M4 (Ret.) 2011 E92 ///M3 (Ret.) |
10-24-2017, 11:04 AM | #15 | |
Rep 6,068
cliverman955.50 |
10-25-2017, 01:29 AM | #16 | |
2JZ-GTE
3072
Rep 4,022
You're on the BMW forum, head to the Apple Store and pony up. |
10-25-2017, 06:55 AM | #17 |
Rep 3,242
If you all are happy with how fast your SATA SSDs are performing, you'll be blown away with M.2 NVMe PCIe SSDs. Many current laptops are now coming with these SSDs as standard. The next step is to move storage right onto the memory bus. We're seeing this with NVRAM technologies and products which are starting to hit the market based on Intel's Optane and 3D Xpoint.
P111593.00 |
10-25-2017, 08:44 AM | #19 | |
Rep 6,068
10-25-2017, 08:45 AM | #20 | ||
Rep 6,068
10-25-2017, 08:51 AM | #21 | |
Rep 7,341
I also have an iMac that I don't even have hooked up anymore. I literally put it in the basement.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
10-25-2017, 10:35 AM | #22 | |
Rep 3,242
Also, not all SSDs are created equal. As an FYI, there are three types of flash memory used in SSDs: SLC, MLC, and TLC. SLC SSDs are stupid expensive but perform the fastest for both read and write operations. These are some times referred as write intensive drives. The others listed fall under mixed use or read intensive applications. In addition, you all should pay attention to a durability rating which some times a manufacturer will list for a consumer grade SSD. Enterprise SSDs always report this parameter. It's called DWPD or drive writes per day. If you want some sort of reliability, you want a drive that has at least a 1 DWPD rating. What this means is if you have a 500GB SSD with a 1 DWPD, this means you can write 500GB of data to the SSD every day for I think 5 years. SSDs do fail. One of my clients tried using Samsung 840/850 EVO drives because they thought an SSD was an SSD. Why spend 2 to 3 times more for an enterprise SSD? Well, they found out as they were burning out their 840/850 drives at an alarming rate. They've since gone to enterprise level drives. I run some servers in my home network and they're using SAS SSD drives rated at 3 to 5 DWPDs with drive sizes of 1.92TB and 3.84TB. |
P111593.00 |
