05-17-2022, 10:59 PM | #1 |
Rep 4,132
does 48V Mild Hybrid actually feed 11hp to drivetrain?
I have searched the ends of the globe and have not found any explanation to how the 48V MH feeds 11hp to the drive train
as far as I'm aware it powers the starter motor, the power steering and some other low powered electrics. i don't even think it powers the AC anyone knows how it feeds 11hp to the drivetrain? thanks (I have a M340i) |
05-18-2022, 03:42 AM | #2 | |
Rep 15,858
It can also simply 'drive' the car along with engine off, on light cruising loads. Last edited by HighlandPete; 05-18-2022 at 03:54 AM.. |
G30M3763.00 |
05-18-2022, 08:44 AM | #3 |
Rep 2,557
It's worth noting to add to this discussion, in the next gen B58 and all new S68 applications debuting on the x7 and new 7 the electric motor will be moving to the transmission vs it's current location on the end of the crank.
HighlandPete6658.50 Rux643.50 |
05-18-2022, 05:15 PM | #4 |
Barge driver
8656
Rep 12,425
Yes it does, there is a graphic display in idrive showing when it's helping it also engages when you select launch control.
I find that it does a good job even though it's only another 11hp.
730d/Z4C
05-19-2022, 09:38 AM | #5 |
Rep 4,210
In my 530e the electric motor replaces the torque converter. Are you saying that the mild hybrid electric motor will do the same?
05-19-2022, 10:19 AM | #6 |
Rep 32
It does, and it displays eBoost on the instrument cluster when it is delivering power (although I think it does at other times too)
More here: https://g05.bimmerpost.com/forums/sh....php?t=1796976 |
05-19-2022, 10:21 AM | #7 | |
Rep 2,557
However the power rating is wild, 147lbft but only 12hp. I have not been able to find the torque rating of the current gen 1 system but I suspect it is significantly less even though the hp is similar. The mild hybrid system is also never fully additive, that 147lbft (or whatever the number is in current application) is used to cover standstill, low rpm, shifting, and turbo lag moments. But is not ever fully pushing on top of peak engine power like a full hybrid would. For example the lci x7 power ratings, the total system (MH + ice) torque peak of the updated b58 is barely above the torque peak of ice alone and for the v8 the rating is the same, despite the 147lbft capability of the electric motor. That tells me the hybrid motor is tapering off as the ice ramps to full power and is only filling gaps. Which makes sense given the smaller batteries. It seems to goal of the mild hybrid system is to work to more fully flatten the torque curve in part throttle moments or when the ice is not fully on the boil. (Also provides a smooth auto/stop start) |
HighlandPete6658.50 Vervain397.50 |
06-03-2022, 12:26 PM | #8 | |
Rep 1,587
That's one think I like about the MB 48v mild hybrid is they don't have any belts, things like the AC compressor is run off the 48V system so even when engine is off (i.e. at a red light) the AC compressor is still running and you still get cold air). BMW Gen 1 48V mild hybrid still has a built and AC compressor still run off the engine, so when engine is not running, you get warm air blown at you. |
06-03-2022, 12:41 PM | #9 | |
Rep 2,557
I haven't seen anything in the materials that calls out they have converted additional subsystems to 48v. the only potential indicator is a throwaway line that the MH battery can feed electrical power back to other vehicle systems, but that is as much detail as i have read. BMWs priority is efficiency and if their math shows in the avg start/stop event the AC coils will remain cold enough for the duration I imagine they prefer to reserve that power for reduced fuel on restart and takeoff |
