Go Back   BMW E60 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      08-05-2024, 09:10 AM   #1
Gsadd
Drives: BMW M140i
Both shoulder wear
Hi guys,
Another post on here, I’ve finally managed to book my car in to check the alignment with a Indy however I still can’t get my head round how my new tyres have developed double shoulder wear (inner and outer) ( see pics for reference) My tyres aren’t under inflated (36psi) so I’m confused on how it’s showing the symptoms that it is, the wear only occurs in passenger side and not the drivers. Any one ever experience this before and give me some help on what I should look for/ do. I’ve seen about “ tyre rotation” online but these are new tyres only been on 2 weeks .TIA. Name:  IMG_7436.jpg
      08-05-2024, 09:36 AM   #2
Tambohamilton
Drives: E91 330d
Can't see any signs of wear in those pics. Can you point it out or explain what you're seeing in a bit more detail?
      08-05-2024, 09:44 AM   #3
Gsadd
Drives: BMW M140i
Its due to them being new tyres so the wear is not 100% obvious but starting to show, if you look on the outer edges you can see the black wear marks ( for example you can see the grey road marks/ dirt in the centre but on the outer edges the wear is faster causing them to black... first image helps you see it better but this is happening on both shoulders) , photos aren't the best, but best i could do to show the initial wear
      08-05-2024, 11:05 AM   #4
tracer bullet
tracer bullet's Avatar
Drives: '25 Z4, '15 X3 35i (135i sold)
Inside edge wear from an alignment problem, outside edge wear from flying around corners?
Both could be from flying around corners if you tend to corner both directions (typically freeway ramps are always the same direction but maybe enough round-abouts can build up cornering wear the opposite direction).
      08-05-2024, 12:12 PM   #5
M3SQRD
M3SQRD's Avatar
3439
Drives: E92 M3,G20 330ix,F22 240iX,F82
It’s likely caused by improper toe setting on one side of the car. People think camber quickly destroys tires but that’s not true. Improper toe settings can destroy a tire in as little as 2-3k miles. Also, the feathering you’re getting on one side is toe related. Get an alignment from a reputable BMW Indy shop.
DrVenture1055.50
M5Rick66832.50
      08-05-2024, 01:36 PM   #6
Tambohamilton
Drives: E91 330d
Do get the alignment checked. But I still can't see the difference
      08-05-2024, 01:39 PM   #7
DrVenture
DrVenture's Avatar
1056
Drives: M550i 2022
Please report back what the shop found, so we can all better understand what was going on. I do see what you are referring to, the smooth black area at the outer 1" of outside and inside tread blocks.
Also, do you have any suspension mods, like aftermarket springs.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Executive|Luxury Seating|M668 w/ DSW06+
      08-05-2024, 02:01 PM   #8
Gsadd
Drives: BMW M140i
Have no mods suspension wise, alll stock, I’m booked in for Friday so will report back then.
      08-05-2024, 03:43 PM   #9
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2012 BMW 335i  [5.25]
2012 BMW 335is  [5.00]
2008 Infiniti QX56  [0.00]
1967 Chevrolet Corv ...  [10.00]
2001 M Roadster  [10.00]
2022 BMW 540i  [0.75]
2009 528i  [9.50]
This is an M140i? I have a '22 540i, as well as a bunch of other BMWs, and I don't think any of them specify the same pressures front and rear. I typically set my pressures at whatever the placard says inside the driver's door. For my G30, that is 33 front, 38 rear (PSI here in the colonies).
      08-05-2024, 06:32 PM   #10
Gsadd
Drives: BMW M140i
Yeh didn’t make it very clear in my description, apologies, I run the same psi as you however I upped the fronts to 36 psi to see if this “wear” would stop but it has carried on.
      08-05-2024, 06:46 PM   #11
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
What is your driving style? Wear this far up the sidewall can only be from driving really hard, e.g. at track, or severe under inflation. Or both.
      08-06-2024, 03:35 AM   #12
Gsadd
Drives: BMW M140i
Most of the time I’m just commuting the car daily, on weekends or some nights I maybe go on spirited drives but wouldn’t say it’s pushed super hard all the time, the psi is 36 on the front would say that’s more than enough rather then under inflated which I can’t get my head round, unless a control arm bushing has been perished and is moving at certain speeds causing uneven wear ?
      08-06-2024, 03:51 AM   #13
Tambohamilton
Drives: E91 330d
IMO, the black bit just isn't in contact with the road, and stays clean. The grey has picked up grit/dust from the road.
      08-06-2024, 06:10 AM   #14
Gsadd
Drives: BMW M140i
Just strange that the other side isn’t doing the same, while both are sat at the same psi, I’ll attach photos for reference
      08-06-2024, 07:08 AM   #15
Tambohamilton
Drives: E91 330d
Not sure, tbh. I can see what you're saying though.
What's the spec pressure range for the front axle? I know for mine 36psi is the minimum. Maybe try pumping it up to the max spec to see if that changes anything?
      08-06-2024, 07:48 AM   #16
Gsadd
Drives: BMW M140i
Minimum is “32” and max loaded is “41”
Just confusing how it’s signs of under inflated, ill pump them up to the higher end and see if there’s any change, it’s off into the shop on Friday for them to check the alignment.
      08-07-2024, 07:49 PM   #17
Redd
Swap your tires left to right and see if the problem follows. If it does it might be an issue with the tire itself, not the car.
ShocknAwe3427.00
      08-09-2024, 07:05 AM   #18
Gsadd
Drives: BMW M140i
So guys, took my car today and got it sorted all it needed was a alignment I’ll insert pic here- Still baffles me how bmw try charging me £1212 when all it need was a alignment
      08-09-2024, 07:13 AM   #19
tracer bullet
Well, give it some time to be certain that's all it was.
      08-09-2024, 02:48 PM   #20
DrVenture
DrVenture's Avatar
1056
Drives: M550i 2022
Nailed it!
