04-19-2017, 11:15 PM | #1 |
Rep 7,455
The Joys of Home Ownership
We got notified today by our water company that they thought we had a leak due to a sudden high consumption rate. There were no obvious signs of leaking in the house. No wet spots on the ceilings or walls. The toilets aren't running and cutting off the dishwasher and washing machines didn't help. We could hear water running in the pipes, but even cutting off the main valve inside the house didn't stop it. That left only the crawlspace.
We have the crawlspace from hell. It's actually just a 3x3 pipe chase that runs between the garage foundation and the foundation of the house. To access it I need to remove a panel high on the wall of the furnace room in the basement and then squeeze my big ass up through the opening. Just what I want to do at 10:30PM. As I was removing the screws holding the access panel, it suddenly popped loose and cracked me in the head. Great way to start. As soon as I removed the panel I knew I'd found the leak. I could hear the water dripping. I got up into the space as far as I needed to shine a flashlight and sure enough, the main water pipe coming up out of the ground had three pinholes right where the first copper fitting is. Water was spraying against the garage foundation wall, which was a lucky break. If it had sprayed the other way, it would have ruined the sheet rock in the furnace room or the ceiling of the furnace room. So the next step was to access the meter pit outside and cut off the flow of water to the house. That was loads of fun late at night, but it went easier that I thought it would. Tomorrow I need to find a plumber willing to come out on very short notice. Never an easy thing around here.
04-20-2017, 12:20 AM | #2 |
Rep 1,060
At least you found the problem, and no sheet rock needed replacement plus painting.
JB4 Tune, MHD backend flash, E85
VRSF 7" Intercooler, BMS OCC VRSF CP & TIAL 50mm BOV, BMP PI DocRace 6266 single turbo. |
04-20-2017, 12:21 AM | #3 |
YouTube.com/TvTara
6454
Rep 4,715
That's awesome that you were notified like that though!
04-20-2017, 01:24 AM | #4 | |
Out to Lunch
616
Rep 19
Naz241627.50 |
04-20-2017, 05:06 AM | #5 |
Schmollbraten
12512
Rep 1,985
Bimmette offers also plumber videos? Wow...now I am really impressed!
///M Power-Belgium63382.00 |
04-20-2017, 05:50 AM | #6 |
Rep 762
Be glad you got a notice. My pipe broke while I was out of town. Got a $3000 water bill. Said I used 500,000 gal. Not a happy camper about that.
04-20-2017, 06:19 AM | #7 |
Rep 364
We used to live in a 3rd floor flat and the pipe came apart under our floor before the stop tap. Flooded all the flats below as water straight from the mains was going for well over an hour until we could find where the stop tap in the road was. As it was all on our water bill we worked out roughly 8cu.m of water worked its was down the building.
Honestly never seen anything like it was coming though light fittings that fast it filled a kitchen bin in 5mins. |
04-20-2017, 07:24 AM | #8 |
Rep 7,455
I'm not messing with this one. It's not a pure copper-to-copper fit. The main line coming up through the ground is some sort of black plastic pipe, as far as I can tell. Then there's a copper fitting somehow attached to that. Then the main copper line for the house comes off the fitting. It's the plastic-to-copper fitting that is cracked. This needs to be done right. I've done plumbing work while building environmental remediation trailers when I was in that field of work, but it's been 20 years and that was standing up in a nice clean shop. Trying to do this laying on my side in a tight crawl space ain't happening.
Worst water leak I ever saw was at a condo the ex and I had. The washing machine hose in the utility room next door to our unit broke at night. The cats woke me up with their howling. I got out of bed and stepped into 2 inches of water on our floor. That mess took months to clean up with numerous carpeting and linoleum flooring replacements. Our current washing machine has a cutoff valve which is always off when we're not doing laundry and the hoses are braided steel instead of rubber.
04-20-2017, 10:44 AM | #9 | |
Rep 4,836
04-20-2017, 11:19 AM | #10 |
"Salud"
13851
Rep 4,675
Drives: F01 & F15 / Mineral White
Sorry to hear this my friend.
We've been in our house for 17yrs, and thank God nothing negative has happened other than our A/C condenser unit going out in the middle of Summer a few years ago. That was the worst timing EVER with 100 degrees in Texas! And take it from me... GET ESTIMATES! At least 3. When Repairmen KNOW you need repairs, that's when they start licking their chops. Good luck with the fix...
04-20-2017, 02:35 PM | #11 |
Rep 7,455
Basement has one. No floor drain in the upper floor laundry room, though.
04-20-2017, 02:37 PM | #12 |
Rep 7,455
My usual plumber came out today and fixed it. I felt bad for him having to crawl into that wet and muddy crawlspace. He got it done, though. I imagine the bill will reflect the nastiness of the job.
04-20-2017, 03:58 PM | #13 |
Rep 1,395
Drives: Porsche 993, 2014 MB GLK
I love old houses, have never owned anything less than 50 years old, my current and hopefully last home is over 100 years old in a Heritage area. We've had the place for 3 years now and have been renovating it as it will be our retirement home. I find that it seems that on a somewhat regular basis I have to stop my reno work and repair something as there is always something that needs attention, I'm good with that for the most part. Keeps me out of trouble. Thank god I can do most of the work myself, if I needed to pay a contractor I'd have gone broke....
04-20-2017, 06:56 PM | #14 | |
Rep 7,455
04-20-2017, 07:39 PM | #15 |
Rep 14,115
Drives: G82 M4C X-Drive
At least they told you and you caught it before any real damage was done. When we bought our house, over the course of the month that it sat empty, a small water leak turned into a $5k water damage bill.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
04-21-2017, 12:27 PM | #17 |
Rep 14,522
ahhhh...i feel your pain OP! bought my house back in Dec 16' and we really didn't move in until March 17' as moving in the winter would have sucked and besides my youngest is a Senior and we did not want to yank him out of school in the middle of the year. we would bring stuff back and forth on the weekends and one weekend there was a puddle of water on our floor from the ceiling above. come to find out the Master Bathroom sink leaked between the drain plug when you fill up the sink. the Home Inspector apparently missed it as you can clearly see the previous owner used some type of clear epoxy to seal it up. apparently when we use the sink when we were there on the weekends the water would just seaped between the seal and drip down the cabinet and make it's way down to where it would just pooled up on top of the ceiling. you could see all the joint tape just wet looking from the main floor when you look up. being a handyman i'm pretty good with drywall and what not. but i ended up tearing part of the ceiling down and replacing it than retexturing with a hopper. this picture just show the new drywall installed and mudded. this would have easily been a $1,000+ job to hire a contractor to repair! ah the Joys of being a home owner !
04-21-2017, 12:51 PM | #18 | |
Rep 14,522
M_Six16965.00 Whostheboss410.00 Xtabi1701.50 ///M Power-Belgium63382.00 Dang3r12512.00 AIRPOWER1682.50 YouAreMyWorld390.00 |
04-21-2017, 12:51 PM | #19 |
Rep 7,455
^^^^We had a similar, although smaller issue like your leak a few years back. The upstairs shower stall drain pipe developed a leak at the goose neck and started dripping onto the ceiling of my office downstairs. We have textured ceilings downstairs as well. I hate them. I had to have a plumber come out and cut a hole through the ceiling of my office and fix the drain, then patch and re-texture the ceiling. Don't remember what that cost us because it was probably a decade ago. We'll see what the bill for this latest fiasco runs. It only took them an hour or so and the part had to be dirt cheap, so I'm hoping it won't be too bad. It depends if they charge us for an "emergency" call.
Damn nice job on the pedestal. Looks great. But you might think about braided steel hoses. See my post above about our nightmare flood when a rubber washing machine hose broke.
04-21-2017, 01:04 PM | #20 | |
Rep 14,522
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 04-21-2017 at 01:09 PM.. |
04-23-2017, 01:48 PM | #21 |
Rep 841
OP i feel your pain.
Back in 2010, i went into my crawl space to clean out the pool filter. It was getting late, so i decided to continue the next day. I left the pool filter and hose open but i forgot to unplug the pool pump. The pool pump automatically turns on every day at noon. The next day, when i came back from work, the entire swimming pool was emptied into my crawl space!!!!!!!!!!!!!!!!!! Let's just say the next few days were hell!
WHO'S THE BOSS
04-23-2017, 07:45 PM | #22 |
Rep 14,522
That had to suck!
