08-22-2011, 11:31 PM | #23 |
Rep 155
08-23-2011, 12:13 AM | #24 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
I've done tons of laps around the ring, and spa, and our tracks here in Vegas. Never popped once. And I can push it. Gotta be the overboost. There's no way all these people just happen to dog the car so bad it pops off.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
08-23-2011, 08:25 AM | #26 |
433
Rep 3,762
Someone's jelly. ^^
08-23-2011, 08:29 AM | #27 | |
Rep 2,898
I also understand that both popped and broken charge pipes have occurred with the M Performance Center's 1M fleet in Spartanburg. Neil Last edited by MDORPHN; 08-23-2011 at 10:36 AM.. |
08-23-2011, 08:38 AM | #28 |
433
Rep 3,762
I wonder what's so different between the m's and non-m's hardware wise? I'll have to check realoem.
08-23-2011, 08:43 AM | #29 | |
European Editor
10596
Rep 22,992
It could be in the 1M's software. I bet in all cases the cars were in M mode... sharper throttle response. The throttle plate opens and closes faster than ssay in a 135i or in normal (1M) mode. So when you jump off the throttle at high boost (low to mid rpms with over boost!) the pressure shock wave takes out the weakest link - being the charge pipe. Just a guess though. |
08-23-2011, 08:51 AM | #30 |
433
Rep 3,762
Yeah that is the most likely scenario if the hard parts are equal.
08-23-2011, 08:55 AM | #32 | |
European Editor
10596
Rep 22,992
Perhaps BMW will fix this mechanical deficiency like they have in the past (x35i's) with a SW update! lol They (BMW) might simply detune these little monsters before it becomes an epidemic problem. Sir.. your 1M needs a new SW update... |
08-23-2011, 09:33 AM | #34 |
433
Rep 3,762
I've never heard complaints on any. I think the meth bungs are usually the deciding factor.
08-23-2011, 11:41 AM | #37 |
CW2
27
Rep 440
Drives: 1SMC - traded away
Mine's done with production but not in transport .
How is it attached? I couldn't see well in the photo. I had this problem on my '08 Sky Redline after I had the ECU remapped. It seemed to spool up faster under load and that's when the charge pipe would pop off. Kind of annoying. GM used those lame screwclamps, but the problem went away with some good T-bolts.
Good-bye, ol' Paint...
08-23-2011, 12:36 PM | #38 |
433
Rep 3,762
I was thinking T-Bolts too, but not sure if it would fit and keep a flush seal with the beveled edge.
08-24-2011, 09:27 AM | #39 |
Rep 154
I'm more worried about high-pressure fuel pump issues with the car. I haven't heard any reports yet, but my '07 335i has had more fuel pumps than it has oil changes, and recently started the first sign of another failure (constant turning over and not starting first thing in the morning, often taking 2-3 times to start).
I am going to look into the aftermarket charge pipe offerings though. |
08-24-2011, 09:35 AM | #40 |
Rep 5,018
Drives: VALNCYA
anyone think maybe it was just loosened during transport?
08-24-2011, 09:35 AM | #41 | |
Rep 2,898
Neil |
08-24-2011, 09:49 AM | #42 |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
08-24-2011, 08:03 PM | #43 |
Stay Ripping
60
Rep 547
My car is currently at the dealer. Dealer called today saying they opened up a puma case and are waiting to here back from the engineers in germany. I am not sure why as it just needs a new charge pipe, but I guess we will see what occurs.
After much research I have decided to go with the ER charge pipe. It clamps to the throttle body using the factory style clamp, comes in a anodized black finish and also allows for the use of the stock diverter valves or aftermarket diverter valves. Alot of the other manufacturers require the use of a bov, which I dont want to use.
THE GOBBLER- S.O.H
08-26-2011, 12:45 PM | #44 |
Rep 574
I'm wondering if I should just go ahead and make this mod to avoid the issue all together?
This is a pretty easy install, right? I figure I'd just go with ER and use the stock diverters. Easy peasy? Why would using a BOV be worse? I admit, I like the sound of them, but do not want to impede performance, reliability or longevity in any way. If staying with the stock diverter valves with an upgrade charge pipe that won't budge under pressure is the way to go, then I'm down for that. HP Autowerks have you guys put one in the 1M. Any notes, write ups?
there is no effing automatic
