05-12-2009, 12:40 PM | #1 |
Rep 723
What is a decent "beginner" road bike?
Any bicyclists out there that can give advice on what to look for when shopping for a first road bike?
I've never ridden a road bike before, only bmx and mountain bikes. Any big difference? How much should I spend on my first bike? Looking to pick this up as a summer activity. |
05-12-2009, 02:03 PM | #2 |
Rep 9,160
Consider used. Lots of sub $1k bikes tend to really short you on component selection. This might sound weird, but consider spending some money on a professional fitting. A properly fitted road bike is better than all the fancy components on a poorly fit bike.
Once you know the size that you need, you should have a fairly easy time finding something to fit. Do you want to do centuries, crits, recreational rides, or a little of each? |
05-12-2009, 02:24 PM | #4 | |
Rep 1,224
Lots of different ways to go and like mtn bikes, you can go crazy expensive over a roady with materials, design, setup, .....Be patient and do some research.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
05-12-2009, 02:28 PM | #5 | |
Rep 2,118
A few more thoughts. Depending on the topography, you may want a triple crankset for the hills. Also, consider frame material. Aluminum is very common in the low to mid-price range. Thick framed aluminum road bikes can ride harshly but the better frames have thinner tubes and some even have carbon forks and rear stays that help the ride. Thanks, Mike. |
05-12-2009, 02:43 PM | #6 | |
Rep 9,160
For the OP, if you can find a bike you like with compact gearing, that can be good for the hills too. Conventional gearing is traditionally 39/53t on the front, while compact is 34/50t and works nearly as well as a triple ring setup and results in a little less chain cross, which is nice. |
05-12-2009, 03:30 PM | #9 |
boku no namae ha...
342
Rep 11,023
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
are you looking for geared, single gear, or fixed gear?
are you looking to build one or are you looking to buy a complete set / +modify to your liking? what kind of frame are you looking for? there's buncha grades of aluminum and then theres steel. when comparing bmx bikes to a road bike, there's a huge difference in geometry. i ride a bmx bike as my daily and my fixy for fun... you feel a huge loss with more chain, plus you run into more problems with more gears (i have pretty bad luck with bikes) i've spent around 1.5k on my fixed gear. around 650-700 with an add on brake+lever, then i bought new set of wheels with tires for like 400, got new pedals/cages/straps for another 150, got a new brake lever for i think 30, and then lastly got a new saddle for 200. i'm thinking of doing another build by starting off fresh with a leader aluminum fixed gear frame stuff adds up, but if you enjoy it--it shouldn't matter too much
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
05-12-2009, 03:50 PM | #10 |
Rep 723
05-12-2009, 04:17 PM | #11 |
Rep 723
05-12-2009, 09:18 PM | #12 |
boku no namae ha...
342
Rep 11,023
nice. some friends and i picked up biking about a year ago... go through some pretty good bike/scenic routes. pretty fun and you get a good workout
05-19-2009, 11:58 PM | #14 |
Registered Sex Offender
597
Rep 4,757
Specialized Sequoia
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
