      03-05-2017, 09:22 AM   #23
bosstones
Drives: o_0
Let's start with: How are you defining performance? "Make it go", handling, or yes?
      03-05-2017, 11:07 AM   #24
Beartato
Beartato's Avatar
882
Drives: M235i
Originally Posted by TheAxiom View Post
I know I'll be in the minority here, but I don't think chassis stiffening has any emperical evidence to support its supposed benefits.
But driver and tires would be the best.
Ever built a drag car?
      03-05-2017, 12:08 PM   #25
kevin65
kevin65's Avatar
Drives: Sport Car
Defining car performance is pretty easy, make it so, it's a long process that require more powerful, or at least more efficient, combustion. More fuel alone going into the engine wouldn't work, because of the delicate rapport between the oxygen in the air and the fuel required for the combustion.
Modifying car's engine to accept more air and fuel is the solution.
      03-05-2017, 06:30 PM   #26
Antetokounmpo
Antetokounmpo's Avatar
Drives: E90 6MT FBO; '18 F150 Platinum
My biggest cringe is when people say coilovers is the first mod to do when tracking.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
MKSixer34184.50
      03-05-2017, 06:50 PM   #27
MKSixer
MKSixer's Avatar
34185
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
I'll go against you here, my friend. If you think about the car as a series of rectangles with the front suspension rectangle comprised of the upper and lower stress bars in the horizontal plane and the shocks and uprights comprising the sides, stiffening the upper and lower stress bars will create a more stable platform for the vertical bits and bobs. In the M6 I went from the plastic, YES PLASTIC, hollow tubes which comprised the upper stress bar to a billet aluminum offering from AC Schnitzer.
The same goes for the rear. I did the same thing in the rear which went from nothing to the Dinan CF piece.
Driving in town...no difference. Pushing the car on the road or at the track, no contest. The results were astounding. The car turns in much sharper, feels about a foot shorter, and is more stable.
Stiffening the chassis only makes a difference in a car that is driven near the edges of it's performance envelope. I can shoot you some pictures of the before and after if you'd like.
Cheers-mk
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
Biorin2784.50
      03-05-2017, 08:30 PM   #28
Msizzle
Drives: 2013 M6 Coupe
we still say "chip" ? I thought it was a tune these days
      03-05-2017, 08:38 PM   #29
Antetokounmpo
Correct. Now we just re-flash the ecu instead of physically replacing the ecu "chip"
kevin6521.50
      03-06-2017, 08:54 AM   #30
silvergray545
Skittles, OT OG
silvergray545's Avatar
Lebanon
2337
Drives: Lots of M cars
2016 BMW M3 ZCP  [0.00]
2000 BMW M Roadster  [0.00]
2004 BMW M3  [0.00]
2014 VW GLI  [0.00]
It's not so much the coilovers that bother me but rather the brands people choose. Koni yellows will take you a long way versus the garbage people buy.
      03-06-2017, 09:02 AM   #31
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Cheers-mk
Not saying the feel isn't better, but how does it translate to actual measurable performance improvements?
kevin6521.50
      03-06-2017, 09:20 AM   #32
silvergray545
Skittles, OT OG
Lebanon
2337
2004 BMW M3  [0.00]
2014 VW GLI  [0.00]
If your chassis is flexing under cornering or braking, it's changing the suspension geometry. Which makes your suspension less effective. That also means the tires no longer have the same contact patch as intended. Less grip all around.
      03-06-2017, 09:22 AM   #33
Antetokounmpo
They don't bother me at all. But when people recommend them as the first mod for tracking.. no. Tires, pads, and fluid will give you much bigger performance improvements (and safety too).
kevin6521.50
      03-06-2017, 09:23 AM   #34
Taskmaster
Japan
2465
That's the theory - but show me actual empirical evidence of this. I actually looked around for a while for some actual measurable benefit. Outside of more driver confidence, it really couldn't find any.
kevin6521.50
      03-06-2017, 09:57 AM   #35
silvergray545
Skittles, OT OG
Lebanon
2337
2004 BMW M3  [0.00]
2014 VW GLI  [0.00]
I don't even consider those mods. If I bring anyone to the track with me, they have to have track pads and fluid at a minimum.
It sounds like you want to see a test where the only variable is the chassis stiffness. I'm guessing that likely doesn't exist.
      03-06-2017, 10:26 AM   #36
Taskmaster
Japan
2465
