      05-10-2011, 09:34 AM   #1
rapter
Drives: 1(M)other f*^#er of a car
1M Crooked Exhaust
For the 1M owners on the forum can you please eye-ball something for me.
If you stand directly behind the 1m, roughly 1-2 feet back at the dead center of the roundel, take a look at the exhaust tips as they protrude from the back of the rear defuser.
On my vehicle the right tips project further out than the left tips.
Can other owners confirm this?
      05-10-2011, 10:16 AM   #2
EmmDrei
Germany
26
Drives: 2011 Saphire Black 1M Coupé
Not the case on my car (if I read you correctly). See: Attachment 522075
The best piece of road - worldwide.
      05-10-2011, 10:19 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Wrong angle. He is saying when you stand behind the car and look DOWN at the exhaust pipes - they stick out uneven from the rear valence/bumper cover.
mmmmmmmmmmmmmmmmmmmmmm
------xx xx
---------------------------------------xx xx
      05-10-2011, 10:36 AM   #4
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
even from this pic, you can see the passengers side is slightly lower and looks like it sticks out just a tad more but it could just be the pic
from my experience w/ other dual exhaust cars in the past (non-BMW), they tend not to be perfectly symmetrical.
      05-10-2011, 10:42 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Maybe that is a sign of "hand made" workmanship.
You would think using a jig would solve that problem. ?
      05-10-2011, 10:46 AM   #6
EmmDrei
Germany
26
Oh... thanks for the clarification, Dackelone!
Are you talking about an angle that they stick out in, rapter or are they straight and stick out more on the right than they do on the left? So looking top down, yours look like this?
II II ........... II II
................. II II
(Hope this "drawing" works. )
@escobar929: If open the image in a graphics program and draw a straight line between the bottom of the rear wheels, then you'll see I was not perfectly center and parallel to the car, when I took the picture, sorry.
      05-10-2011, 11:00 AM   #7
rapter
Thanks for the clarification
I am actually saying that they stick out straight but the right tips project slightly further than the left tips do.
The angle appears to be fine.
      05-10-2011, 11:20 AM   #8
DriveHard
DriveHard's Avatar
Colombia
115
Drives: X1 and R58 JCW
ON a car i have access to, i see no real difference when looking down directly..
phone pics.. sorry thats all i got.
the first pic is the drivers side ( usa) second is passanger side (usa)
i was a little more directly over the drivers side when taking pic, but i saw no difference.. maybe if you wanna be really anal less than a mm.. in all directions.
EDIT >>>>> I TAKE IT ALL BACK... it was dark where it was parked
it was brought inside.. the right side does stick out further then the left... 3 or 4 mm at best.. manufacturing tolerance i guess ??? not really noticable espically since most peoples view of theses pipes will be as they pull away from them at a very high rate of speed
X1, R58 JCW, M2 in my future if planets align
      05-10-2011, 11:22 AM   #9
EmmDrei
Germany
26
So... just re-checked.
If I stand dead center, directly behind the car and then move back until I see the exhaust tips, then I will see the right tips before I see the left tips. I would say there is a 2-3mm difference. Nothing I would have noticed otherwise, though.
      05-10-2011, 11:30 AM   #10
rapter
I have seen some other pics of the car on the net today and I see the same thing that I am seeing on my car.
You are correct the difference is about 5mm, but really I don't think that I care all that much... curiosity more than anything else.
      05-10-2011, 11:42 AM   #11
MrRoboto
Drives: VO 1M
Is it possible to simply adjust the chrome tips a bit?
      05-10-2011, 11:45 AM   #12
rapter
I should take a peek under the vehicle to see if there is a mechanical connection on the tips so that they can be pulled back slightly.
It would be a good time to do it as the car is still really clean.
On a side note: I think that I would be very happy if these tips are removable as I would promptly send them to be powder-coated black!
      05-10-2011, 11:51 AM   #13
EmmDrei
Germany
26
According to RealOEM they are.
Hmmm... good idea you had there! Thanks!
      05-10-2011, 11:54 AM   #14
discoboy1
discoboy1's Avatar
Drives: E82 1M VO/F30 328D
I think they are spot welded, bu i could be wrong...
2011 E82 1M VO
2013 F84 35i VO
      05-10-2011, 11:55 AM   #15
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
I noticed that the same day I picked up the car. It's not a huge deal for me as it will be coming off soon.
Harold
      05-10-2011, 11:56 AM   #16
1Mer
Drives: 1 Series M Coupe
Let us know how easy they are to get off?
Thanks
      05-10-2011, 11:57 AM   #17
DriveHard
DriveHard's Avatar
Colombia
115
Harold
LOL... and so the metamorphisis begins..........
      05-10-2011, 01:06 PM   #18
rapter
If they are spot welded then there will be a little bit of an ordeal to remove them .
Thinking about it, I don't know that having a threaded connection at this part/ point of the vehicle would be a smart move. The weather conditions would without a doubt seize the threads and make removing it impossible.
      05-10-2011, 01:20 PM   #19
darkvaderr
Drives: 1M ordered
They look (from the pictures I've seen), exactly like the M3 tips, which are simple attached via rivets. The rivets also look accessible without removal of the exhaust or rear bumper
      05-10-2011, 02:04 PM   #20
Stratus650
United Arab Emirates
189
Drives: 1er M Coupe
Guys, some parts of the exhaust might slightly expand or contract while hot/cold. It might be the case here.
'12 Candy Grey Metallic 1M
      05-10-2011, 02:56 PM   #21
Dan Parker
Drives: 2012 Golf R
Mine are straight and even. Perhaps the heating up and down has loosened yours. I only have 320 miles on mine.
Dan Parker
      05-10-2011, 03:47 PM   #22
1SerieStud
1SerieStud's Avatar
183
Drives: '11 VO 1M (498 of 740)
I'm with this 100%...2 of my friends one who drives a 1-series and another who drives a 3-series, both experience expansion and contraction of the exhaust tips depending on how hot their cars run. I've seen it with my own eyes, and they can expand up to 0.5-1 inch!
1addicts
