BMW M2 Forum > Regional Forums > UK > UK warranty ?
      05-04-2022, 11:08 PM   #1
dstow13
Drives: BMW M2C ; Ford Mustang GT
UK warranty ?
I'm an American living in the UK and I have the Miltek OPF back exhaust on my 2019 M2C. My end of warranty check is in a few weeks, but I have also purchased an extended warranty through BMW. As I am unfamiliar with UK dealers/warranties, my question is since I have the Miltek exhaust on, will this void my warranty?
      05-05-2022, 11:14 AM   #2
SW6Steve
Drives: F30 330d
I believe they don't like any alterations from factory.
Do what most do and don't mention it.
It's basically down to the dealer you use, If they want to make an issue out of it.
I have bmw extended warranty, plenty of mods, all be it mostly oem. Have made a couple of claims, and not had an issue with my dealer.
      05-13-2022, 02:35 PM   #3
otee10
otee10's Avatar
Drives: F87 M2 LCI
Would only be exhaust related issues that are void.
      05-15-2022, 04:33 AM   #4
Carrera2RS
Drives: BMW M2
Unless there is an engine failure and they suggest it was exhaust related which it couldn't be, but I have seen BMW try.... depends if you have a decent dealer. Just back box should be a OK
      12-23-2023, 10:46 AM   #5
Andrew2
Scotland
180
Drives: M2 OG DCT
Insured - Extended Warranty
Recent experience re. a broken rear coil spring ...
Dealer initial diagnosis - failure due to corrosion hence not covered by the warranty - upon reviewing their pictures I could see that this was not the case - it was only the paint coating that was corroded and not the spring material - upon review the dealer agreed and the claim was upheld
NB - BMW policy
Spring fails due to corrosion - the pair should be replaced
Spring fails due to `other` defect - only that item needs to be replaced
Having read and re-read my Insured Warranty policy, if the claim had not been upheld I would have not accepted this and taken it further
m2
