XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      04-06-2023, 06:52 PM   #1
chaicc
Drives: BMW X7
bad smell from vents X1 2014
Hi, I am bit confused on the location of filters( i watched several youtube videos) and followed 1 to replace cabin air filter which is located outside under the hood. It's a long filter.
But since the smell is still bad, i saw a video where a mechanic replaced 2 cabin air filters which are located inside under the glovebox on passenger side.
Does X1 28i 2014 have these inside-cabin-filters and do i need to replace them to get rid of smell?
I took the car to dealership and they did Frigi-Fresh thing but no difference in smell. Pls help
      04-27-2023, 08:42 AM   #2
jawry2
Drives: 2013 BMW X1 drive 28i
What does it smell like? Burning oil smell or like mildew?
      04-27-2023, 08:47 AM   #3
chaicc
Drives: BMW X7
Smells like mildew or rusted pipe
      04-27-2023, 08:59 AM   #4
jawry2
Apparently some have had success with spraying Lysol on the evaporator. If you remove the cabin filter that is located under the hood at the base of the windscreen, you can see the blower motor. I believe the evaporator is located under the blower motor. I have not tried this btw.
      04-27-2023, 09:02 AM   #5
chaicc
Drives: BMW X7
Ok. By the way it smells when i just run fan and A/C is off.
With A/C ON, it doesn't smell.
Thanks i will try lysol
      04-27-2023, 09:14 AM   #6
jawry2
Yes, the fan is still drawing air over the evaporator, even with the a/c off, which is likely where the mildew smell is coming from. Let me know how it goes!
      05-01-2023, 06:20 PM   #7
cwickberg
Drives: X1 35i MSport Ultimate,
This dirty sock smell has been an issue for BMW's for years and years... good luck... Google it... lots of treatments
      05-02-2023, 12:28 AM   #8
chaicc
Drives: BMW X7
Thanks yeah i did. And most solutions are spraying Lyzol in air intake vent.
      05-02-2023, 02:29 PM   #9
SharpAndCunning
Drives: 2014 X1 35i
Interesting. My brothes says my car smells like Crayons. (He's the only one with kids and there are never crayons in the car). I'm going to try this.
xbimmers
