12-24-2021, 03:27 PM | #68 |
Rep 172
I am pretty that that's bs. My laptop has a dedicated Ethernet port, and I was able to do some coding in Esys without trouble.
BimmerBahn441.00 |
01-24-2022, 11:59 AM | #70 | |
Generalissimo
660
Rep 1,417
01-24-2022, 12:46 PM | #71 |
Rep 183
01-24-2022, 03:09 PM | #72 |
Rep 6,872
FWIW, the coder may have different tools based on the hardware you have available at your end. It's easier to use what they're comfortable with, and obviously what they support, so verify with them beforehand.
01-25-2022, 09:44 AM | #73 | |
Generalissimo
660
Rep 1,417
01-25-2022, 09:49 AM | #74 | ||
Rep 8,767
Drives: eVeRyOnE mAD!
01-25-2022, 10:24 AM | #75 |
Generalissimo
660
Rep 1,417
One Facebook 45e forum member who did the 21 kWh update back in the summer is telling me that the app didn't show kWh usage only a couple of times after the update. Also, I did have an issue before the 21 kWh update with kWh usage not showing at all for the whole month of September so I suspect it's just an app issue.
01-25-2022, 02:26 PM | #76 | |
Rep 116
Thanks for the update and doing this. |
01-26-2022, 12:04 PM | #77 |
Rep 146
even X5 sold in Germany are built in USA?
01-26-2022, 12:17 PM | #79 | |
Rep 2,951
Drives: 2020 BMW 530xe
It will work without issue, but will introduce increased battery wear and BMW won't warranty that additional wear... But that's true for any mods generally that cause extra wear. |
02-25-2022, 10:31 PM | #82 |
Rep 620
02-27-2022, 11:16 AM | #83 |
Rep 49
Why is it different in the U.S.?
02-27-2022, 12:36 PM | #84 |
Rep 8,767
02-27-2022, 03:54 PM | #86 | |
Rep 8,767
charge cycles compared when charged from 0-100%: full 24kWh = 1 charge cycle EU 21.6kWh = 0.9 charge cycle US 17.1kWh = 0.7 charge cycle the higher the charge cycles, the greater negative effect on overall battery health. for example, if someone in the EU fully charged their 45e from empty twice, it would be 1.8 charge cycles. if someone in the US did that, it would be 1.4 charge cycles. |
cptcolo103.50 |
02-27-2022, 04:16 PM | #87 |
Rep 114
It has to be said the 45e batterie can be repaired selectively, should that become necessary. There are repair instructions for the 4 big modules, and then again for the individual cell blocks in each module. Won't be cheap due to labor, but apparently can be done by certified dealers - no shipping of complete replacement batteries.
cptcolo103.50 |
02-27-2022, 04:28 PM | #88 | |
Rep 8,767
BMW replaces the entire module even if only 1 cell within that module is defective; they do not replace individual cells. last November, I had 1 defective cell in module 4; that entire module of 16 cells was replaced. so if any number of individual cells are defective in each of the 12 modules, then the entire battery assembly will have to be replaced (worst case scenario, of course, but i know of 2 guys going through it right now here in the US). |
cptcolo103.50 |
