BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Eisenmann performance exhaust f90 slower?
      11-12-2018, 11:58 PM   #1
Catchmeifyoucanf90
Drives: f90 white m5
Installed the axle back Eisenmann performance exhaust on my car. I also have the m performance "resonator delete" the mid pipe. Anyways, since i have installed the axle back Eisenmann performance exhaust on my car I feel as if the car has become slower 0-60. Was wondering if anybody else has felt this or has a clue. Thank you
      11-13-2018, 06:46 AM   #2
onfireX5
Drives: F90M5,F85X5M
You won’t gain or lose power from a cat back. Are you using Dragy ?
      11-13-2018, 08:53 AM   #3
Hunter399
Hunter399's Avatar
323
Drives: F90M5
Have any videos of it?
      11-13-2018, 12:56 PM   #4
Ragazzi-07
Ragazzi-07's Avatar
Drives: 2018 M5
I've also heard this....its due to the back pressure the car feels sluggish.
      11-13-2018, 01:58 PM   #5
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Not on mine
I have race version and none resonated mid Pipes
Life is too short...enjoy your life
///M
      11-15-2018, 08:29 PM   #6
Catchmeifyoucanf90
So have I actually lost speed in 0-60. I’m so curious I feel like I might just put stock back on. Not really impressed with the exhaust to be honest
      11-15-2018, 11:03 PM   #7
Catchmeifyoucanf90
Originally Posted by Miko M View Post
Not on mine
Not on mine
Do you miss the electric value system? And can you still be quiet to be under the radar around cops
      11-16-2018, 05:07 AM   #8
Miko M
///M
Miko M's Avatar
Not on mine
Not on mine
I don't miss the valve control at all
If i drive around town or cops, i just switch to efficient mode ad D1 and it's half the noise
///M
      11-16-2018, 07:11 AM   #9
Nate@IND
Nate@IND's Avatar
2868
The backpressure debate is a common myth on car forums-
http://www.gomog.com/allmorgan/exhaustbackpressure.html
3. How did the myth about back pressure and big pipes come to be?
I believe it is/was a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a Honda Civic decides he's going to upgrade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the power band. He makes the connections in the following manner: "My wider exhaust eliminated all back pressure but I lost power, therefore the motor must need some back pressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero back pressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
Are the valves functioning correctly?
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
Remonster824.00
      11-16-2018, 07:29 PM   #10
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Unless you have a leak, there should be no change in performance
https://x-ph.com/sale/
Phone number 702-494-9435
      11-16-2018, 10:06 PM   #11
Catchmeifyoucanf90
Not sure if the Valves are working correctly, there are times where there's barely any sound when I down shift, like dead quiet in sport + and everything open, but it's so inconsistent. Also have the m performance mid pipe
Tags
eisenman exhaust, f90, f90 m5
m5post
