BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Code Ambient Lighting with BimmerCode
      03-06-2022, 12:32 PM   #23
rzorsan
Drives: BMW X1 F48
Hi...
we have disassembled the door panel of an f48 and we have only seen this blue 4-pin connector. we believe it is sound and not ambient light. What is your opinion?
      03-06-2022, 12:36 PM   #24
djadam
Italy
28
Drives: X1 F48
Yeah, unfortunately that's definitely not an LED connector which is smaller (2 pins) and black.
      03-06-2022, 12:45 PM   #25
rzorsan
Drives: BMW X1 F48
The oem connector has 3 pins....
      03-06-2022, 12:47 PM   #26
djadam
Italy
28
Drives: X1 F48
Sorry, typo, I meant 3. The blue one has 4.
You should have two black connectors anyway in the door as there are 2 led modules and 2 strips per front door.
      03-20-2022, 06:25 AM   #27
rzorsan
Drives: BMW X1 F48
We keep moving forward with the topic....
Yesterday a colleague who has requisitioned the ambient lights of an Alliexpress kit gave me these codes so that in our Xs the intensity can be unlinked from that of the frame and the 2 colors (orange/white) that the equipped ones have as standard can be used.
With Bimmercode this makes the Idrive menu active:
HU_NBT > HMI 3000 > COLOR_SWITCH > aktiv > activate menu
HU_NBT > HMI 3000 > COLOR_SWITCH_LINES > urban > determine vehicle color scheme (urban, modern, sport, luxury)
HU_NBT > HMI 3000 > HELLIGKEIT_AMBILIGHT > aktiv > Ambient intensity menu activated.
And works!!
And with this it must be unlinked from the lights roulette of the box and that it obeys the Idrive menu...
Fembody > 3070 > Ambience_Helligkeit > wert_01 >wert_01 ; 0.64 > 0.99 > Brightness Ambient light
Fembody > 3070> Ambiente_Nachfuehrung > nicht aktiv > Brightness setting of Ambient light becomes independent from the brightness setting of the instrument cluster
The first one changes the value and is for the maximum brightness
The second is to make it independent
But it doesn't work for me... no matter how much I select the color or brightness from the Idrive, it only obeys the roulette, and doesn't change color... it works for him, although he doesn't use the serial cable as us... something else must be missing.
djadam28.00
      03-29-2022, 11:45 AM   #28
BMWORLDM
Spain
Drives: BMW G20 & F45
Hi, I’ve a BMW F45 and I bought this 2 pieces to retrofit de ambient lightning. The problem is when I turn on the lights, this ambient light doesn’t work. Is it necessary to do coding with bimmercode or something like that? could the led module have come faulty? Thanks.
      03-30-2022, 02:56 AM   #29
djadam
Italy
28
Drives: X1 F48
I guess your best bet would be to test if there is any current in the plug whilst the car and lights are on.
Current ok > Check LED module.
No current > Probably not connected or needs coding.
      04-01-2022, 08:35 AM   #30
BMWORLDM
Spain
Question
can I do it with bimmercode?
      04-11-2022, 12:20 AM   #31
smartg
Greece
Drives: f48
2016 f48   [0.00]
So whilst I was installing my new screen I found out I had the LED connectors preinstalled behind the dash trim.
I bough and installed an OEM light strip and LED head and everything works (see pic for result).
My current questions are:
I did not have the factory ambient lighting option so this is basically a retrofit, which means I have no settings in the iDrive menu, can they be added somehow (BimmerCode)?
Has anyone tried taking apart the doors? Is there a chance the connectors are also inside the door panels (before I start opening everything up)?
Thanks!
helppp i did not have the factory ambient lighting but i find the wire back from the trim i connect led module but no light i need coding to give access!! i have bimmercode. Thanxs sorry for my poor English
      12-01-2022, 05:16 PM   #32
DevilzGtr
Drives: BMW X1
Hi, this is what I ordered:
Light strip: 63319321262
LED module: 63319353133
Hi, where do you order these parts from? Directly from the dealers?
Also, which section of the trim did you find the wiring?
I've checked at the far end oppersite the steering wheel and couldn't see any cable ends.
      12-02-2022, 02:48 AM   #33
djadam
Italy
28
Drives: X1 F48
I bought them from https://www.hubauer-shop.de/en/
Also this is another good option: https://www.leebmann24.de/
Check the first few pics for the trim, basically the part above the glove box.
      12-05-2022, 03:48 PM   #34
DevilzGtr
Drives: BMW X1
Amazing, thank you so much for the links and advice, I found the spare cable hidden in my vehicle (image attached)
The links show the part numbers (Light strip: 63319321262, LED module: 63319353133) you quoted are for LHD car I think but I'm guessing they are compatible with my UK RHD X1 too?
      02-27-2023, 08:28 AM   #35
bear7364
Drives: BMW F45
Hi, did you ever get this to work as I have the same issue ?!
      02-28-2023, 03:56 PM   #36
DevilzGtr
Drives: BMW X1
No coding required to get it lighting up in orange. Did you test it out in the evening when its dark? I noticed it only comes on when it's dark. I did this mod over the weekend and really happy with it. Thanks to OP for this thread
      03-01-2023, 07:26 AM   #37
bear7364
Drives: BMW F45
Yeah, I tried at night and also measured for voltage but could not get any voltage readings. I also powered up the LED with a 9 volt battery to make sure it lights up and it did !
      01-31-2024, 04:26 AM   #38
jk_rvz135
Drives: BMW X1 2019
Originally Posted by Beams View Post
Thank you! I've found the parts and placed order
How did you order them as it gives me an error when ordering since I am not in the EU and so it requires a total purchase price of 157,87 EUR.
      03-28-2024, 03:22 AM   #39
coathangers
Drives: E90 318i
Hi I bought these for my X1 F48 2016 as I noticed the connector under the passenger side dashboard. Plugged them in correctly and they aren't working
I even did the bimmercode of the HU_NBT so I have the menu items
Did you do anything else? Was this just plug and play for you?
Thanks
xbimmers
