04-14-2011, 03:55 AM | #1 |
Rep 1
need help choosing case for my pc
hello there. I need a new case for my pc and kind of in a tiht budget here so under 200$ would be fine.anyone here got some idea where to buy one with a good quality?I did found one in south-pak . com and it's beautiful. But I just don't have any idea on buying it online and stuff. What do you think? And also, would it be possible if I'll be like painting the case? Just to make it more like personalized and design it on my own.
04-14-2011, 11:11 AM | #2 |
Rep 3,288
Do you want a mid-tower or full tower? ATX is the way to go as most mobo's and other parts use the ATX standard size.
Antec is a good company, so is Cooler Master. My 2 prefered Mid-Tower cases right now are below. Cooler Master Storm Scout: $79 http://www.newegg.com/Product/Produc...82E16811119196 Antec 902: $109 http://www.newegg.com/Product/Produc...82E16811129097 For Buying online, Newegg is probably your safest bet with the best Customer Service and decent pricing. If you have a Fry's Electronics locally you can sometimes find better deals on cases in their Brick and Mortar shops. But not always.
04-14-2011, 12:37 PM | #4 |
Rep 1,502
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
04-14-2011, 01:37 PM | #5 |
Rep 5,417
This is going to be my build...
Case X-CRUISER2-BK 59.99 http://www.compusa.com/applications/...230&CatId=1842 Power 1000 Watt Silverstone OP1000-E (SLI / Crossfire Compatible) 189.99* http://www.tigerdirect.com/applicati...?EdpNo=6624659 Motherboard Gigabyte GA-P67A-UD7 – P67 Chipset, SLI & Crossfire, 1GB LAN, USB 3.0, iEEE, SATA 3 329.99 http://www.newegg.com/Product/Produc...82E16813128480 CPU Intel i7 Sandy Bridge Quad Core 2600K 3.4GHz 8MB L3 Cache 319.99 http://www.newegg.com/Product/Produc...82E16813128480 cooling Liquid cooling system CPU heat exchanger with integrated pump - ( Socket 775, Socket 1156, Socket AM2, Socket AM2+, Socket 1366, Socket AM3, Socket 1155 ) - copper - 120 mm 83.99 http://www.cdw.com/shop/products/Ant...ER%20H2O%20620 Graphics card ATI Radeon 2GB HD 5870 GDDR5 260 http://www.newegg.com/Product/Produc...82E16814102888 RAM CORSAIR DOMINATOR GT 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory with Airflow Fan Model CMT8GX3M2A2000C9 214.99 http://www.newegg.com/Product/Produc...82E16820145330 RAM CORSAIR DOMINATOR GT 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory with Airflow Fan Model CMT8GX3M2A2000C9 214.99 http://www.newegg.com/Product/Produc...82E16820145330 HHD Intel X25-M Mainstream SSDSA2M160G2XXX 2.5" 160GB SATA II MLC Internal Solid State Drive (SSD) - OEM 400 http://www.newegg.com/Product/Produc...-20167017-_-NA OS "Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM " 100 http://www.newegg.com/Product/Produc...oft-_-32116754 CD ROM LITE-ON Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal 4X Blu-ray Reader Model iHOS104-06 - OEM 60 http://www.newegg.com/Product/Produc...82E16827106325 Total 2043.94 |
04-14-2011, 01:45 PM | #6 |
One cam is enough
132
Rep 6,801
I've always gone with CoolerMaster, specifically the CM690, COSMOS S, and the HAF.
The CM690 is good if you're trying to keep the size somewhat down while still provide plenty of space and air cooling, while the COSMOS S and HAF have space for the 3x120 radiators if you're going to do serious WC. However, I have not shopped for cases since the new sizes came out (X-ATX is it?) so if you're looking for one of those, I'm not sure what to suggest but I'm pretty sure the HAF can accommodate it due to the fact that it's got space on the top and bottom for the PS. |
04-14-2011, 06:38 PM | #8 |
Rep 3,288
I should mention that full ATX towers like some poeple are recommending are very large. VERY LARGE. And the good ones (Steel Frame) are heavy.
So if you end up going with one, just be aware they aren't the most mobile things.
04-14-2011, 06:46 PM | #9 | |
Rep 3,288
04-15-2011, 08:04 AM | #10 |
One cam is enough
132
Rep 6,801
04-15-2011, 08:16 AM | #11 |
Rep 3,288
No worries. I thought maybe you had heard of some new standard size to take care of the problem with longer and longer graphics cards.
I think E-ATX is longer in the height dimension not width though.
04-15-2011, 08:22 AM | #12 |
One cam is enough
132
Rep 6,801
Yeah it's just longer in length and I think you might be able to drop a double PCIe x16 off the bottom. Width is exactly the same.
04-15-2011, 01:01 PM | #13 |
stick to your guns
20
Rep 441
i just got a Cooler Master HAF and am loving it.
"Speed has never killed anyone...suddenly becoming stationary, thats what gets you."-Jeremy Clarkson
04-15-2011, 03:25 PM | #14 |
Rep 1,528
+1
the HAF is the way to go. For the price, you get amazing cooling plus you can have a lot of options when it comes to cooling. You can have a ton of small fans, or have big fans, or have water cooling. The case is setup for all those cooling options, plus it looks pretty cool. mid tower: http://www.tigerdirect.com/applicati...&Sku=C283-1223 full tower: http://www.tigerdirect.com/applicati...&Sku=C283-1187
Muffler Delete/ Tien S-tech Springs / De-badged /BBS LM Reps 19"/ Nexen tires/DTM M5 Front bumper/ Injen Intake/Blacklines/M-tech Rear/Custom Muffler Tips.... More mods to come
