03-10-2016, 08:37 AM | #67 |
2nd Asst to Dept Undersecretary
6704
Rep 1,298
Drives: People crazy
Not sure possible... Don't talk about negotiating options with someone whose nick is actually OptionLESS
This space for rent.
03-10-2016, 08:40 AM | #70 | |
Rep 25
This should be a very basic concept if you have been a part of startups or really any company that awards stock units. |
03-10-2016, 08:46 AM | #71 | |
Rep 25
Would you mind letting me know the value of these 1000 shares? Obviously you know the number of shares that have been issued and the valuation of the company |
03-10-2016, 08:55 AM | #72 | |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
He is reporting to a VP. You don't know his proposed level in the company which is why I asked those questions. Typically, Directors of many different stripes report to VPs. Based on this information I KNOW that 1,000 options is a low number. I have led and work on teams that designed compensation plans for both large corporations with hundreds of sales persons and small start-ups that don't even have sales forces but are in the process of building one. My last was designing a sales force of about 100 all making a minimum of $120K with a non-at-risk total compensation of roughly $200K and at-risk-compensation, for the hitters approaching an additional $300K. Options to start for these people were approximately 2,000. He stated in an earlier post that he will be charged with building a division/silo/whatever under a VP. THAT should make him at least AD or D level. An appropriate number of OPTIONS for a person of that level is 20,000 +. An appropriate number of options for the sales force/workers/fisherpersons/whatever he is attempting to build is in the 1,000 to 2,000 range. "$$ difference in about 30k + stock prior to IPO. No idea what they are in the running of making/what they are raising though. Stock price is probably not going to be that high" |
03-10-2016, 08:59 AM | #73 | |
Rep 25
On what basis are you determining the value of 1000 shares of the company OP is considering joining. Oh I see you edited it in now. "Stock price is probably not high" Great, thanks for knocking it out of the park for us. Heh. |
03-10-2016, 09:00 AM | #74 | |
6704
Rep 1,298
Rule of thumb for most startups (particularly in tech) is 10 Million shares authorized. Founders usually actually get ISSUED 50-75% of those. So, that leaves (generally) 2.5-5Million shares to go around. Based on any rational valuation (and most irrational ones) 1,000 is low for a reasonably early-phased employee. Lot's of risk, deserves commensurate reward. Given he is a direct report to a VP and also the only one in the department, fair to assume he is "early phase". We are all making assumptions here. But the advice was far from retarded.
03-10-2016, 09:01 AM | #75 | |
Rep 11,637
03-10-2016, 09:01 AM | #76 |
Rep 4,819
Many pre-IPO companies have low share counts, so I think it is highly dependent on shares outstanding if getting in before an IPO / share split. If you get 1,000 share / options when 100,000 shares are outstanding (1%) and the shares are split 100:1 in the IPO you end up with 100,000 after the IPO at the IPO price. No way to know what 1,000 implies value-wise without knowing more about the existing capital structure.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
03-10-2016, 09:03 AM | #77 | |
Rep 11,637
Reporting to VP. Check Ask for more than 1,000. The advice. |
03-10-2016, 09:06 AM | #78 |
Rep 878
OP,
The dynamic for switching jobs,careers and industries is a tough one. I think some of the questiosns you need to consider are: 1. How much does money matter at the moment? If you have a family,mortgage,tuitions, etc. that will impact your answer. If you are single, that will allow you more room to take some risk. 2. Do you see yourself retiring with your current company? If not, you need to consider why and what you next employment opportunity should look like. If you are not going to retire there, use it for what its good for and move on (resume builder, experience, etc.) 3. Personality. Are you able to jump out of your comfort zone and go into something else? I think this is something you know better than any of us. You should probably answer that. 4. Finally, if you left your current employer today and took this new job opportunity. If it didn't work out, do you think you would be able to go back to your old company? If you think they will take you back in the event that things did not work out, that might make the decision less risky. Good luck! -Vin
BMW GARAGE: 2006 M5 | 2011 M3 | 2020 X3M
IG: @THEIRRATIONALCARGUY Retired: 99' BMW M3 - 05' BMW M3 - 08' BMW M3- 07' Porsche 997TT - 09' Audi R8 - 94' Toyota Supra TT - 16' F80 M3 AND MANY MORE |
03-10-2016, 09:08 AM | #79 | |
6704
Rep 1,298
03-10-2016, 09:11 AM | #80 | |
Rep 25
Not only do we know exactly the value of 1000 shares, but we also know that this startup has robust corporate structure and anyone reporting to a VP is obviously a very high level employee demanding more stock. Disregard the fact that OP's current job is shooting media, he's obviously transferring into an executive roll. |
03-10-2016, 09:16 AM | #81 |
Rep 168
1000 Shares
Hello
1000 shares might be good. I did a startup in the 80's and had 1000 shares along with two other founders. There were 3000 shares total. Later went IPO/NASDAQ with 95,000 shares at $6 for my share. So it was pretty good. However, later company was de-listed, then relisted, then went NY Stock exchange and shares went for $30. This all took 15 years. By then, I had liquidated most of my 95,000 shares. So you cannot say much without knowing how many shares there are at this point. And you don't know what the IPO will do. Our IPO multiplier was neary 100 which is typical. Went back into the private sector and worked 30 years for a great company and have a pension with medical coverage. So I worked both ends against the middle. I am 71 and have a retirement job doing what I love. I make 10% of what I did in corporate world, but its very rewarding. I am not rich, but comfortable. Sin_Gas
Current: "17 i3 REX; X3 30e
History: '67 911S, '72 MB 280 SE 4.5; '74 2002, E21 ('78 320i, E28 ('85 535i) , E36 ('90 325i), 6 Volvos; '14 ForTwo eDrive; '15 i3 REX, F31--'15 328 D Sportwagen; F25 LCI '16 X3 D |
03-10-2016, 09:37 AM | #83 |
6704
Rep 1,298
03-10-2016, 10:30 AM | #84 | ||
Rep 4,819
03-10-2016, 10:34 AM | #85 |
Rep 300
My thread, my beautiful thread! If I wasn't on mobile I'd have some emojis to drop in here.
Edit: found the emoji Last edited by FType22; 03-10-2016 at 10:55 AM.. |
03-10-2016, 10:54 AM | #86 | |
Rep 300
2.i don't see myself retiring here 3. I think I need to jump in order to grow my career and in the process, myself. 4. I think it's possible they would take me back if they had budget for my head count but I have a good relationship with the people I work with here so doing freelance could be an end all fall back. That or McDonald's. |
03-10-2016, 12:47 PM | #87 |
2JZ-GTE
3005
Rep 3,986
Are we talking unicorns? I don't think so. Love the unicorns.
03-10-2016, 01:06 PM | #88 |
6704
Rep 1,298
Me too... they are delicious, especially over a nice risotto.
