BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Eisenmann race exhaust video
      08-11-2018, 03:05 PM   #1
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Made a small video for you guys :-)
New video from inside
One more from outside
Life is too short...enjoy your life
///M
      08-11-2018, 03:36 PM   #2
onfireX5
Drives: F90M5,F85X5M
Sounds killer !
Miko M6655.50
      08-11-2018, 03:36 PM   #3
rj1079
Drives: 2018 m5 F10
Is this the race or performance?
      08-11-2018, 03:38 PM   #4
Miko M
///M
Miko M's Avatar
Race with non resonated mid pipes
///M
      08-11-2018, 04:53 PM   #5
rj1079
Drives: 2018 m5 F10
How is it for a DD? I'm deciding between the two but I drive long distances sometimes
      08-11-2018, 04:59 PM   #6
Miko M
///M
Miko M's Avatar
It's not bad, just don't keep it in higher gear with low RPM. Lol
Or keep it in efficient mode and S1 so you can control shifting.
I usually drive in efficient mode until warms up and then sport plus and S3
I know I will add intake and down pipes too :-)
///M
      08-14-2018, 02:04 PM   #7
Vic55
Vic55's Avatar
19365
Drives: 2023 BMW M8 Competition Coupe
How would just the cans sound with the M Sport Exhaust mid section??? I couldnt find a video... will these cans add sound?
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      08-14-2018, 05:06 PM   #8
Nate@IND
Nate@IND's Avatar
2870
Did you get an F90 now? I remember when you had the F10
I've personally only heard this system with the non-resonated center pipes. The valve controlled exhaust in Sport+ mode (factory center pipe) has a DB level of 93. In comfort mode the DB will be the same as factory but with a deeper tone.
We also just released the Valved black series with carbon tips
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
Miko M6655.50
      08-14-2018, 05:17 PM   #9
Vic55
Vic55's Avatar
19365
Thanks Nate for the reply.
I havent yet but its coming... go to the M5 Versus section here and you can see my writeup on a 2 day test run against my E63S.
So to clarify, with the factor pipes (cat back) to the exhaust; with the Eisenmann it has a 93 dB. But whats the DB with your full system?
I ask because if I get the car it will have the sport exhaust and Im thinking I want more DB's but not sure I want to gut the entire system vs maybe pulling the resonator and/or changing the rear section.
      08-14-2018, 05:52 PM   #10
Miko M
///M
Miko M's Avatar
I want those Carbon tips... it needs to match the carbon diffuser that I have
///M
      08-15-2018, 01:51 PM   #11
Nate@IND
Nate@IND's Avatar
2870
I sent Eisenmann Germany an email to see if they have db levels for the center pipe + rear section and have not heard back yet. Will update right when we find out.
      08-15-2018, 01:52 PM   #12
Nate@IND
Nate@IND's Avatar
2870
Carbon tips are back in stock and we just finished the prototype front lip
      08-15-2018, 01:53 PM   #13
Miko M
///M
Miko M's Avatar
Nice!!!
I can't wait :-)
///M
      08-22-2018, 11:17 AM   #14
Hunter399
Hunter399's Avatar
325
Drives: F90M5
Really looking forward to hearing just the muffler without X pipes!
      08-26-2018, 09:04 AM   #15
rj1079
Drives: 2018 m5 F10
Same here. I ordered the race and I hope it's not to loud. I'll be running stock pipes.
      08-26-2018, 09:39 AM   #16
Miko M
///M
Miko M's Avatar
I am sure it will be just fine. Cold start will be louder but after you drive it it's not bad.
For me with mid pipes ( non resonated ) is perfect.
I am actually gone add down pipes and intake next month.
///M
      08-26-2018, 09:42 AM   #17
rj1079
Drives: 2018 m5 F10
Do you get the cracks and pops in comfort mode?
      08-26-2018, 10:15 AM   #18
Miko M
///M
Miko M's Avatar
Yes, but not as much and not as loud.
I use comfort mode and D1 just to warm up the car, after that it's sport plus and S3.
Like to shift mine self :-)
Miss the manual more then I thought.
///M
      08-26-2018, 10:57 AM   #19
Hunter399
Hunter399's Avatar
325
Drives: F90M5
When do you think you will have it installed?
      08-26-2018, 11:00 AM   #20
rj1079
Drives: 2018 m5 F10
Should be getting it in a week and half and I talked shortly after. I figured I'd give it a try. If it's to loud for what I need(I drive the highway a lot) than I'll be putting it on the classifieds.
      08-26-2018, 11:05 AM   #21
Hunter399
Hunter399's Avatar
325
Drives: F90M5
Sounds good, looking forward to hearing it.
Did you order it from IND?
      08-26-2018, 11:08 AM   #22
rj1079
Drives: 2018 m5 F10
AutoTalent
m5post
