10-06-2021, 11:38 PM | #1 |
Rep 1,146
any blood suckers out there ?
Not sure if this should be in the sub forum H&F
but want some "thoughts" on bloodtests. So, (without too much of a back story) I used to take annual blood tests, then semi (after diabetes), jan I had some issues, was hospitilised for 1.5 months, with permanent IV's for 2 or 3 times daily bloodwork (in icu) After release, I was doing 3 weekly clinic appts with blooddraws. So, I have basically problems giving blood, it ranges from getting so tense, the blood doesnt flow, to being told I have fine veins, brown skin also tends to hide veins I'm told. Also now I understand, if you get poked regulalry, the veins don't have time to heal and then they can scar, so what was a good vein dries up. So instead of one poke, I now get at least 2 pokes before they can find a vein. Today the nurse said, "oh you've got good veins, I can see them" and then "oh dear, not giving me any today" I've tried, drinking water prior, stop taking anything which will dehydrate me, use a moisteriser on my arms to make the skin softer. I'm also on water reduction (no more than 1.5lt.s a day) and diuretics which makes things worse. At this point I'm running out of theories and options. A nurse saying "you really need to be less tense and calm" doesnt work LOL anyone in the same boat, or any proffesional's mythbust what I've heard. txs |
10-07-2021, 05:59 AM | #3 |
Rep 2,304
Drives: 9Y0 Cayenne S
Blood tests and more are covered in the health and fitness section thread.
You are describing white coat syndrome. Sorry to say but you need to find a way to get over it or work through it. I sympathize, and encourage you to grow beyond the difficulty. |
nazali1298.00 |
10-07-2021, 06:04 AM | #4 |
Rep 3,241
Yes, they're called Robocallers and Telemarketers....
Oh you meant a different blood sucker. |
paquet629.50 RMachuca3d722.00 |
10-07-2021, 07:48 AM | #5 |
Rep 694
10-07-2021, 08:58 AM | #7 | |
Rep 978
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
nazali1298.00 |
10-07-2021, 09:51 AM | #8 |
Rep 1,146
txs, I did look up WCS, at my last clinic check they check HR, O2 and BP,
this was noted, that they always see an increase in HR I'll have a search in H&F section as well txs and yes it's something I have to deal with, some people tell you to relax, then other tell you to make a fist and pump, that like contrary to being relaxed LOL Yes I do find when I relax it's somewhat better, when the blood flows I totally relax, until the moment there digging around that's when I'm tense. One of my first doc's told me, it's the adrenaline that squeezes the veins and said the trick is too relax, |
10-07-2021, 09:59 AM | #9 | |
Rep 1,146
txs, never heard that . good info, can you comment on this scarring of the veins I was told in ICU.
The worst experience I had, was one nurse, poked me 3 times before she gave up, at that point your body is like super stressed. The needles themself don't, hurt, a mild pinch, it's the anxiety of is the blood flowing and do they need to repoke me, is something going wrong. I found out that after the initial prick they remove the needle and whats in the vein is just a soft plastic, I had these imaginings of a metal needle, poking and digging around looking for a vein. I found also the vacuum thing works much better I always used to have a good arm, but now that is not so and I guess y main worry is that due to constant regular bloodwork my veins will mess up I know it sounds silly, but I'm now having bloodwork due to my medical issues and med checks very regular. I hate dentists for the same reason, as a kid I had a lot of ortho work and they would never numb the area, just go right in with a needle, it was worse than a zombie movie Quote:
M3LISSA784.50 |
10-07-2021, 10:01 AM | #10 |
Rep 1,907
I dunno about being harder if you have blood taken all the time, probably true. What I do know is the skills of the person taking the blood matters a lot. I use to go to the same doctor for many years and they did the blood in house. The old lady that took the blood ALWAYS got it in one shot with almost no pain.
That doctor retired and I have since gone to others, some did it in house, some send you off to quest or something. I find that now it's 100% dependent on who I get. I will NOT do it at the doctors office anymore because it seems they are typically the least skilled of all. I had one poke me so many time I told her to fuck off and give me paperwork to go to lab. The lab I find is good 90% of the time. I guess since all they do is draw blood all day they are pretty good at it. |
10-07-2021, 10:05 AM | #11 |
Rep 139
The veins that nurses access during blood draws are superficial surface veins. If you want them to be more visible and easily accessible, you should consider losing weight and strength training. Losing weight removes subcutaneous fat underneath the skin. Strength training increases the vein size to transport higher blood volume.
I write this respectfully, but if this is a long-term issue, losing weight and strength training may be the best way to make blood draws easier. And I suspect your anxiety will decrease substantially once your veins are easier to draw from. |
10-07-2021, 10:08 AM | #12 | |
Rep 1,146
your right on with that, so I get blood drawn either at a hospital or a lab, which is the only thing they do. I sometimes ask for the same nurse, if she's there, but there not always.
I find if after one go, they will say, "let me get a senior nurse" FFS ! I was also told, depending on how they prick you, if you feel it, you tense up, if not, it always flows, Funny thing is afterwards, the point bleeds like a mother LOL In ICU, they girls that came round, daily in the morning, were like fantastic, in and out, in 30 seconds, no pain, I guess your right, this is a major part of it Quote:
10-07-2021, 10:08 AM | #13 |
Rep 147
Drinking water can help, sodium is the key. Salt load with a salty food 30 minutes before the scheduled blood draw. Some people are over excreters of sodium and it makes it difficult to draw blood. Also can make them constipated or urinate less frequently.
nazali1298.00 |
10-07-2021, 10:11 AM | #14 | |
Rep 1,146
txs for the advise, and sure I understand with no offense taken.
After hospital I'd lost about 10kg, due to health concerns i have to watch how and what I exercise, although it's not forbidden. I will take a look at that aspect. I do have to weigh myself daily, to monitor for water retention, and my weight "is" somewhat of an issee for my condition. But I was in the overweight, now I'm in the normal range for BMI When you say strength, your talking about weights as opposed to cardio, ATM I do biking Quote:
10-07-2021, 10:15 AM | #15 |
Rep 1,146
I'm on a low sodium diet, and the day before I drink (try) regular, but my limit is 1.5lt a day.
Also the hospital is looking for sodium levels, yesterday's draw was K and Na and Urea. Plus I'm on the diuretics. I don't think loading up with sodium 30 minutes before a draw will skew the results too much, but not sure |
10-07-2021, 10:26 AM | #16 | |
Rep 147
nazali1298.00 |
10-07-2021, 10:37 AM | #17 |
Rep 1,146
my bloodwork came back good today
Sodium 140 135-145mmol/L Potassium 4.9 3.5-5.2mmol/L Urea 4.1 2.7-8.4mmol/L Creatinine 68 67-117umol/L Glomerular Filtration Rate (eGFR) 102 (higher than 90) |
10-07-2021, 11:07 AM | #19 | |
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
My home IV nurse had to do weekly blood draws for the lab, and she had problems almost every week. She said that it was common with dehydration or fluid restrictions with diuretics. Even the phlebotomists at the blood lab had to try 2-3 times to find a working site. This slowly resolved itself over 1-2 years, and I'm still on the same low-sodium, fluid restrictions, and diuretics doses for severe CHF.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
nazali1298.00 |
10-07-2021, 11:39 AM | #20 | |
Rep 2,039
Drives: 2022 X6///M Comp
My veins suck, my mother has the same issue. I've had this issue all my life, even when I was skin and bones. My GP does it herself and hits it right the first time, every time. When I have to go to the lab, or even worse, when I donate blood they poke the hell out of me. I'm not nervous about it, it just pisses me off when they can't find my vein. I tell them up front to get me someone senior. The last time I gave blood, I felt like a pin cushion. They tried both arms and failed, then tried the top of my hand and failed again. The needle going in isn't the bad part, it's the fishing around once they are in there but not in the vein. That reminds me, it's time for me to donate again.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
nazali1298.00 |
10-07-2021, 12:28 PM | #21 |
Rep 943
Drives: F30 328i Msport
Nurses gawk at my veins, im one of those easy ones ......
Until i needed a picc line installed to feed me through my arm, the line has to go through the arm and into the heart, the damn tube kept going up my neck instead of down to the heart, 45mins later and a shit load of blood squirts the tech finally managed to wiggle it into the right artery. |
10-07-2021, 12:48 PM | #22 |
17963
Rep 9,377
I'm tense just thinking about this. I go every 3 months
My procedure is to get all worked up talking to the nurse, but try to lighten things up with at least one joke about which arm to use. I always point at the nurse. Then I tense EVERYTHING in my body, except the arm they are using, and look away. So I can have 90% of my tension, but that one arm is good. |
nazali1298.00 |
